Samsung 245BW cold start problem
  • Satyrias
    • Mar 2017
    • 5
    • US
    Everyday morning for the last one week, when I turn on the PC, the Samsung SyncMaster 245BW display doesn't show anything, just a black screen. Then I just disconnect the power to the monitor or flip the switch in the back, the display comes back live.
    I noticed that, it happens when temperature in the room is below 75F, other times it is as normal.
    Anybody knows what is causing this?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Samsung 245BW cold start problem
    The name of this website is your answer
    • Satyrias
      • Mar 2017
      • 5
      • US
      So, give any clue to which capacitor?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8694
        If you don't have a tester, you should replace all of them, or at least the ones that are leaking.
        • 1supertech
          • Apr 2012
          • 384
          or bloating
          • re-atari
            • Oct 2010
            • 136
            Check the numerous threads about the 245B and 245B Plus in this corner of Badcaps.net, invaluable info on this particular failure and how to fix it awaits you.
            re-atari
            • Satyrias
              • Mar 2017
              • 5
              • US
              I found two bulged Capacitors in my monitor. Both of them are 1000 uF, 10 V, 105 C.
              I have been looking to buy two capacitors to replace. I prefer Panasonic, but I can't find one or don't know where to look.
              I am not familiar with this, so the silly questions .
              1. Is this a correct part showing in this link?
              https://www.digikey.com/product-deta...4-1-ND/1662564
              It says "lead free". If there is no lead how do I solder it?
              Where can I find a Panasonic capacitor with the above specification?
              2. I saw a repair kit for Samsung 245. It comes with 15 capacitors and 3 resistors. It says, " We only use the highest quality Panasonic, Nichicon and Rubycon capacitors in our repair kits "
              I wonder if those capacitors are genuine or counterfeit. Anybody has any experience with them? Here is the link
              https://www.amazon.com/Repair-Samsun.../dp/B0067G3HAQ
              Please give me some advice regarding this.
              I don't have any idea which one to buy.
                • 30977
                what is the diameter & height of the bad caps?
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  It means it does not contain any lead:
                  https://en.wikipedia.org/wiki/Restri...nces_Directive
                  • Satyrias
                    • Mar 2017
                    • 5
                    • US
                    I didn't take Caps out of the board to measure and don't have the specification sheet. This power board model is BN44-00173A. I put everything back and using the same monitor now since I don't have a spare one.
                    But I took a picture of it. Please take a look at it.
                      09-07-2024, 05:50 AM
                    • howardc64
                      Samsung UN55JU650DF network/streaming problem
                      by howardc64
                      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                      07-09-2025, 12:44 PM
                    • falcontech
                      Samsung Syncmaster 943B problem
                      by falcontech
                      Hello
                      I have a problem with a samsung 943B, initially thinking it was a power problem i replaced the power board which is a bn44-00082e, i had a flashing of the ccfl lamps and the monitor would not start, i replaced the power board and the problem is remained, thinking they were the lamps I tested them with a ccfl lamp tester and they are all working, at this point I think it is the main board which is a BN41-01172B, my question is, before making a further purchase there is a way to turn on the lamps without the main board to exclude that the new power board is also broken? Of course without...
                      02-16-2022, 12:54 PM
                      09-06-2024, 11:40 PM
