Recapping failure
+ More Options
Posts
  • Neongreen
    • Oct 2008
    • 11
    Recapping failure
    Hiya,
    I recently recapped a AOC LM721A; the inverter inside had about 5 bulging caps on a multilayer PCB. I took the easy route and snipped the old caps off and soldered the new ones onto the previous caps' stems, as I wasn't keen to have to deal with desoldering them.
    Now, instead of briefly lighting up then turning off, the monitor is 100% dead.
    I've checked the resistance across each solder joint and they're all perfectly fine, I resoldered the ones that had a slightly higher resistance.
    All caps are on the right way, I double checked.
    Any ideas?
  • Wizard
    • Mar 2008
    • 2296
    Re: Recapping failure
    Are you using low ESR capacitors? Not the jelly beans capacitors that you found locally or direct from idiot electronic supplier?
    Cheers, Wizard
    • Fizzycapola
      • Oct 2006
      • 423
      Soldering legs to legs may have increased the ESR too much. When soldering legs to legs, then taking a measurement, my ESR meter reads ~ +0.01 higher than usual versus directly attaching the gold clips to the caps legs.
      Rubycon Rubycon Rubycon
      • Neongreen
        • Oct 2008
        • 11
        I'm based in NZ so purchasing low ESR caps is a devils task; however I've recapped a few monitors and the normal lytics seem to work fine. I've never had a problem with them. I replaced Hermei caps, were they also low ESR?
        Is there a way for me to test the ESR? I only have a multimeter handy.
        • Wizard
          • Mar 2008
          • 2296
          give the us the markings on the new caps with other writings on it.
          Cheers, Wizard
          • i4004
            • Oct 2006
            • 2029
            >Any ideas?
            well, troubleshoot it.
            if all you do is swap caps and expect them to work, some of them(monitors) just won't work, as caps were not main problem.
            if it's dead, then concentrate on psu and horizontal output(both of which have voltages that can kill you, btw.).
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Did you put any in backwards?
              Mann-Made Global Warming.
              - Dr Seuss
              • Neongreen
                • Oct 2008
                • 11
                I'd expect them to atleast function similarly as before I recapped it if the capacitors were not indeed the problem; EG, in this specific monitor it would turn off after an indeterminate period of time.
                I have now desoldered the legs and replaced them with capacitors, however this has not solved the problem. Evidently the capacitors themselves are either the wrong way around(unlikely as I checked this several times) or they're the wrong type which is what I'd believe. Are the Hermei 470uF 16V caps that are usually in LCDs low ESR?
                I have troubleshooted it; the bulging/leaky capacitors are the only fault I could find and recapping completely killed the monitor. I wanted to make sure there wasn't something simple I was missing or overlooking in relation to the technique.
                The new caps are Suntan 470uF 16V radial type caps with a temp tolerance of 105 deg C and have a Y shaped vent.
                Thanks all for helping by the way, I appreciate it.
                EDIT:
                Yep, I'm fairly confident none are the wrong way around but I'll just check once more.
                • Neongreen
                  • Oct 2008
                  • 11
                  I've double checked each capacitor, and I've continuity tested the entire circuit, and it seems as though the whole thing has continuity(even from the power board to the status LED). I'm going to keep poking and prodding however.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Just the 'brand' of cap doesn't help to know ESR.
                    Need to know the 'series' [a.k.a. "model"] of the caps too.
                    Even then specs for Hermei and/or Suntan may be hard to find.
                    [Haven't looked yet, no point until series is known.]
                    The polarity silkscreen on some PCB's is backwards.
                    Most mark the Negative side but some mark the Positive side instead.
                    [Asus motherboards are famous for that.]
                    It's best to make a map of the caps (and show polarity) on the PCB before you disassemble.
                    [A few snapshots of affected areas works good too.]
                    It's also possible the silkscreen has an error where one/some of the polarities are marked wrong.
                    It's possible heat damaged new caps when you installed if you didn't get it done fast enough. (Or one/some were just duds.)
                    It's not usual but some circuits may need a minimum ESR to function properly.
                    ESR can be used to create a voltage drop at some frequency and that can be used as part of a voltage divider to BIAS something. - To turn on or off a transistor for instance.
                    Such use is not common/typical but it could be done.
                    Most likely the old bad caps damaged something else on the PCB and a shorted or open bad cap allowed momentary function of the screen.
                    - Dr Seuss
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      http://www.hermei.com.tw/factory_e.htm
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        http://www.suntan.com.hk/productindex.htm
                        - Dr Seuss
                        • Neongreen
                          • Oct 2008
                          • 11
                          Thanks a million PCBONEZ,
                          I verified the polarity on each cap as I desoldered it, and marked it's location. Should I desolder each capacitor and test them?
                          The capacitors didn't have any other series markings, but I have found the Hermei capacitors in question are of the LZ series. Through elimination, I have found the Suntan caps are - there's a small chance I'm wrong but without any markings to go on, and just sizes, it's the closest I could get.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Now for the particular sizes you have check the ripple and ESR for the LZ against the ratings for the Suntan's to see if the ratings are in the ball park.
                            Lower ESR is better and higher ripple is better.
                            If ESR is not listed they are GP (General Purpose) caps and just go by ripple.
                            While not a pleasant thought that may be necessary at some point.
                            If the ratings of the caps you used turns out to be okay and you didn't use too much heat getting them installed then basic tracing and checking the circuit is probably the best next step.
                            Also look at your soldering jobs and make sure you didn't get a blob or drop of solder on there somewhere that's shorting a/some traces. It doesn't take much.
                            Same-same any scratches that might have opened traces.
                            - Dr Seuss
                            • Neongreen
                              • Oct 2008
                              • 11
                              The leakage is identical on both of those capacitors, and the ripple current is in the ballpark; it's higher for the Suntans.
                              Just looking it over, there's one point where a pad/ring thing is missing around a solder point. Looks like I must've lifted it and lost it while I was desoldering. Would this affect it? The solder fulls the hole though so I don't know. Plus it has continuity with the rest of the circut. No solder blobs or scratches which could cause a short that I could see.
                              • arneson
                                • Sep 2005
                                • 1267
                                Normally I'd agree that your missing ring would not be an issue, but you say it's a layered circuit.
                                I also figured you soldered to the leads to eliminate the problems of stressing pads.
                                You should look very closely at that one cap and examine the hole physically and measure it for continuety.
                                Then start to look at other component failure as 4004 said.
                                Jim
                                • Neongreen
                                  • Oct 2008
                                  • 11
                                  I'm going to examine the cap and then start looking at other components. I will let you know what I find.
                                  • i4004
                                    • Oct 2006
                                    • 2029
                                    hehe, i said horizontal output in a lcd thread.
                                    something to note: i usually think about crts when somebody mentions monitor(as i don't really check model etc.) and yeah, with lcds there indeed is less to troubleshoot...
                                    you also probably don't have the electric diagram or service manual, and that doesn't help either....
                                    anyway, you don't have much choice but to check studd you already did and then look elsewhere after that...
                                    • Sus256
                                      HISENSE 65E7KQ PRO - no boot
                                      by Sus256
                                      Hi all!
                                      HISENSE 65E7KQ PRO
                                      RSAG7.820.13512 - chassis
                                      MT9618BAATAB - cpu
                                      RSAG7.820.12059 - power
                                      HD650Y3U77 - panel
                                      KLM8G1GETF - emmc
                                      The TV does not turn on, the standby indicator is on. All voltages are present.
                                      Emms is dead. Not readable, not detected.
                                      Replaced emmc.
                                      But with another dump there is no launch
                                      Terminal log
                                      UART
                                      AC_ON
                                      RPMB key is not yet programmed
                                      HASH1_VERSION=0x00000000 64bit
                                      E-B
                                      FDE enabled
                                      layout pattern onebin by SAR7,0...
                                      06-01-2025, 02:11 AM
                                    • ctroxtell
                                      Carrier HK50AA063 display controller common failure help
                                      by ctroxtell
                                      I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                                      02-05-2025, 05:31 PM
                                    • proxneo
                                      Recapping Sony ICF-SW55 - verifying cap values
                                      by proxneo
                                      Dear reader
                                      I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                                      At the moment, I have selected replacements based on the following list of values:
                                      3 x 470uF 10VDC
                                      3 x 4.7uF 35VDC
                                      4 x 47uF 50VDC
                                      8 x 22uF 6.3 VDC
                                      1 x 220uF 6.3VDC
                                      5 x 100uF 6.3VDC
                                      Which...
                                      06-21-2023, 12:38 AM
                                    • howardc64
                                      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                      by howardc64
                                      Problem
                                      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                      Model & Board Pics
                                      Conflicting Spec
                                      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                      https://www.shopjimmy.com/vizio-gj-2k1...
                                      10-10-2024, 01:16 PM
                                      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                      by sam_sam_sam
                                      I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                      Found shorted diodes on main controller relays there are 3 of them that...
                                      01-07-2023, 05:43 PM
