Benq Q7T4 FP71G
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4498
    • Italy - Milan
    Re: Benq Q7T4 FP71G
    Canadan: get a piece of metal wire (copper wire 4 exmpl) thin the point (tip) and wrap around the the iron tip leaving one lead over the iron tip, use this thin "second" tip to solder the tiny fuse, to desolder it use the cutter gently..
    • Vivio
      • Feb 2011
      • 6
      Re: Benq Q7T4 FP71G
      Sorry for reviving the thread, but I have a problem with this monitor also.
      In the inverter zone I had the electrolytic capacitors with the electrolyte liquid leaked. So I've replaced them all.
      Beside that I have replaced the two MOSFET and the all 4 2SC5707.
      Since I did not had 220nF/160V i have used some old ones. The picofuse was replaced with a normal one rated 3,15V/250V.
      After several days the monitor is having the same defect: nu illumination.
      From what I read here I'll do the following:
      1. replace again the MOSFET and 2SC5707
      2. put new 220nF/160V
      3. solder all the connections in the inverter area
      4. replace again the picofuse with a 3,15A one
      Do you think I do the right thing?
      • retiredcaps
        • Apr 2010
        • 9271
        Re: Benq Q7T4 FP71G
        You must resolder all the inverter transformer pins otherwise the picofuse is likely to blow again.
        --- begin sig file ---
        --- end sig file ---
        • EGuevarae
          • Nov 2008
          • 1336
          Re: Benq Q7T4 FP71G
          And the 07's will go too.Resolder All areas that you see odd/strange.
          Post pics. And what about the other caps?
          There are 10 kind of people in this world: those that understand binary, and those who don't.
          • ASUS ROG Maximus IX Code
          • Intel Core i5-7600K 3.8GHz
          • 16gb GSKILL TridentZ RGB DDR4-3200
          • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
          • Windows 10 Pro x64
          • GeForce GT1050
            2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
          • Vivio
            • Feb 2011
            • 6
            Re: Benq Q7T4 FP71G
            retiredcaps thank you!
            EGuevarae
            to be sure the 2 MOSFET and the 4 2SC5707 will be replaced, along with the capacitors between them: 220nF/160V.
            The picture is from the first repair right after the monitor was opened and the quality is not that great. Sorry for that.
            In the pic is shown with RED: all the components that have been already replaced the first time and I will not be replace them now. Exception is the 220nF/160V.
            With BLUE: the components that I intend to replace. The first time I have not replaced C811, but I will do it now just to be sure.
            That picofuse give me nightmares, is such a problem if I put a normal fuse in there?
            My girl was very happy when I had repaired her monitor the first time. Hope I'll do it again A late valentine present
            Thanks for your advices!
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              Re: Benq Q7T4 FP71G
              On ebay, you can buy "c5707 kit" which will have the c5707s, fu9024 fets, and a picofuse. Price is around $4 USD.
              Unless the grey cap is visibly bad, you don't have to replace it. We don't hear much about those caps going bad although it is possible. At minimum, add some fresh solder to the cap legs.
              • Vivio
                • Feb 2011
                • 6
                #27
                Re: Benq Q7T4 FP71G
                One of those gray caps had some problems. At first repair I had put some old caps from a cannibalized TV Now I'll buy new ones to be sure.
                At the same price I can buy the c5707s, fu9024 here in Romania from a store directly without waiting for the package and paying the shipment more then the parts itself. The problem is to find a proper replacement for the picofuse. That makes me mad
                Thanks for your input!
                • Vivio
                  • Feb 2011
                  • 6
                  #28
                  Re: Benq Q7T4 FP71G
                  Update:
                  I have replaced the 2 MOSFET and the 4 2SC5707, along with the capacitors between them: 220nF/160V.
                  The picofuse has been replaced with an part that is almost similar FSK03.15
                  Also, I have soldered the whole inverter area. For two weeks the monitor works well, hope it will last forever
                  • killian6pk
                    • Apr 2010
                    • 502
                    Re: Benq Q7T4 FP71G
                    Were you able to get the bezel and back plastic case completely apart. The one I am working on does not want to come apart in the center of the button bar. There seems to be an injection molded connection between the top and bottom plastic. If you have some idea how these two pieces come apart, I would appreciate it if you could let me know.
                    Have you ever stopped to think and then forget to start thinking again?
                    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
                    • Vivio
                      • Feb 2011
                      • 6
                      #30
                      Re: Benq Q7T4 FP71G
                      well, not my best work...
                      At the button level I have squizzed a small screwdriver and little by little the lid was freed.
                      There are few marks, maybe look for another advise also
                      • killian6pk
                        • Apr 2010
                        • 502
                        Re: Benq Q7T4 FP71G
                        Thanks, I found out it is under the part of the stand that stays attached to the monitor. You have to take two screws out of that stand part and slide that part out of the back of the monitor and then there is a small screw that you can get out and the two halves of the plastic case come apart.
                        • Vivio
                          • Feb 2011
                          • 6
                          #32
                          Re: Benq Q7T4 FP71G
                          Sorry I thought you have taken out the screws. My problem was to detach the silver cover
                          • killian6pk
                            • Apr 2010
                            • 502
                            Re: Benq Q7T4 FP71G
                            You have to take off the two stand offs that the VGA Plug Screws into. Then that cover will slide off. I bent mine a little also until I realized those two were actually through the silver cover also.
                            • cmlewis89
                              LG 47LB5DF blown power supply board
                              by cmlewis89
                              Hi folks,
                              I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                              09-03-2024, 07:50 PM
                            • Caspar
                              BENQ GW2780-T power board blown
                              by Caspar
                              Hi all, I am looking for some help in ID'ing some parts in an attempt to fix a power supply from a GW2780-T monitor. The power supply PN is 715G7300-P02-006-0V3R. I have been looking around for the PN and it appear the board was used by other OEMs as well (ASUS, Viewsonic). If anyone has a schematic, it would be helpful.
                              Quick look on the underside of the board, I can see:
                              -D905 is blown - ? value
                              -R920 is open - 1Ω ?W
                              -R927 is open - 20Ω ?W
                              On top side, I see:
                              -R931 open - 0.68Ω ?W
                              Metered short:
                              -P9NK65ZFP...
                              06-01-2022, 05:16 PM
                            • drscoot
                              HP X360 convertible battery blown fuse error, not charging
                              by drscoot
                              HP Modelnumber: 14-dh0061nb​
                              This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                              The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                              I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                              And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                              All these 3 batteries are charging...
                              12-15-2023, 05:54 AM
                            • swerg
                              Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                              by swerg
                              Hey everyone,
                              I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                              I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                              I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                              06-06-2024, 03:39 PM
                            • ohren
                              What problems could this blown cap cause in a Marantz SR5400?
                              by ohren
                              I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
                              R533 right below it in the photo is charred, but measures the correct value.
                              1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
                              10-21-2025, 09:02 AM
