EADP-64BF B troubleshooting guide?
  • speedracer2016
    • Nov 2016
    Hello all. I am new to the forum so bare with me. I have a popular Viewsonic VP2030b LCD monitor. Some time back it just died - NO POWER LIGHT - NO NOTHING.. I am trying to fix it for another computer I inherited. Logically, if the monitor doesn't power up one would tend to look at the power supply. I am NOT as fortunate as the many others that have found 'blown' caps on their power board and that fixed it. The board is removed from the monitor rear and I have looked at this board with a magnifying glass and none of the caps appear to be blown. I have ohmed out from the power plug through the switch to the other side of the 15 amp fuse and all was ok. Rather than chase my tail, is there a way, with the board on my bench, that I can plug in the power cord and check the output to see if it's there or not which would certainly speed up the repair process (power board is bad or problem lies elsewhere)? On the lower edge of the board I see a box with 8 voltages printed in it. On connector CN1 there just happens to be 8 pins. Is this the correct table for that connector and output voltages? One gentleman on YOUtube was stating a monitor/computer power supply typically has to be turned "on" by jumpering several pins on the power supply board. I see the ON/OFF pin but (if his remarks are true) what would I jumper ON/OFF to? IF there is a guide/manual/pdf in another forum tab please let me know and I will go there. I did look at the "gone in 2 seconds" guide but that did NOT apply as it does NOT power up at all. Thanks for any input, guidance or help offered.
    Re: EADP-64BF B troubleshooting guide?
    You can run the power supply board by itself because it is an always on power supply, so when you apply 120Vac to the board, you should see some DCV at the connector that goes to the logic board.
    We also need to see the pictures of YOUR boards.
    • speedracer2016
      • Nov 2016
      Thanks for the response. I will check on how to put pictures on the forum.
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • penangit
        Hp v193 monitor power supply board
        by penangit
        Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
        I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
        I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
        Steps taken so far:
        Checked all...
        02-21-2023, 04:00 AM
        by momaka
        03-15-2023, 10:17 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
