Dell S2409Wb power switch bypass?
  • freakytiki4u
    Coolest Member
    • Aug 2009
    • 130
    Anyone know how to bypass the Monitor Power Switch on a Dell S2409Wb Monitor? They power switches on these monitors are incredibly fragile and I would like to completely bypass the factory power switch and install one of my own or tell me which points to jump so I can get it come on. Thank you for any assistance.
  • Powderfanupnorf
    Dell AL440LX power on switch circuit help required
    by Powderfanupnorf
    Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
    So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
    My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
    06-24-2024, 01:24 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • Borse2008
    by Borse2008
    • There’s
    07-15-2025, 04:55 AM
  • zlr8r
    Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
    by zlr8r
    hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
    Ill try and give as much info as I can.
    Dell Inspiron 17 (7786) Laptop
    Service Tag: 5J0NHT2
    Bios: 1.9.0
    When I received this , it would only flicker on the KB backlight for a second, then off and on.
    Then it started getting weirder!
    Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
    12-12-2023, 09:31 PM
  • grimacelord
    NEC TurboExpress On/Off Power Switch Replacement Help
    by grimacelord
    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
    11-09-2023, 09:49 AM
