Vertical Lines on LG E2211 LED LCD
  • FrankMtl
    • Sep 2015
    • 36
    Could it be the ribbon cable?
    I check the boards and they look fine.
    The lines are there the monitor is connected to a pc or not.
    Thanks.
    Frank.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Vertical Lines on LG E2211 LED LCD
    Failed Lcd panel not fixable sorry.
    • FrankMtl
      • Sep 2015
      • 36
      Thanks, I found the monitor so it's ok.
      Here is a picture of the monitor with ribbon cable disconnected.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Thats because with no power the Lcd falls open (only seeing backlight here, all light let through) and when power is applied the failed tab then loads the lines and cant deselect them due to be shorted.
        • FrankMtl
          • Sep 2015
          • 36
          Thanks, I guess it will go to the E Bin.
          Frank.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            No worries sorry for your loss lol
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
              by momaka
              03-15-2023, 10:17 PM
            • jackster
              Samsung Curved monitor C27FG70FQU with garbled vertical lines on startup
              by jackster
              I acquired a faulty curved Samsung C27FG70FQU which has the quite common problem of just showing weird vertical lines for a while after a cold boot.
              The issue is pretty bad with this one and it takes about 15 minutes before things normalize and a proper image is displayed. Once a proper image is shown it will work 100% until the display is shut down or put in standby for a while and allowed to cool for a bit.
              Even though this seems to be a quite common issue I haven't really found any information regarding what the root cause is and how to fix it. There is this video...
              02-13-2023, 01:56 PM
            • gpo23
              Sony KDL-40V3000 - Vertical lines
              by gpo23
              i order a t-con because i had bad colors on my SONY KDL-40V3000 :
              With the new t-con the color are good but there are vertical lines on all the screen :
              I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
              Is there a way to fix the vertical lines on the new t-con ?
              Thank you for your help
              gpo23...
              10-04-2023, 09:11 AM
            • nick@nickarchdale.com
              HP LP3065 monitor has developed vertical lines
              by nick@nickarchdale.com
              Hi all.
              My much beloved and long serving monitor has slowly been developing a fault ever since I switched to Windows 7 and started "docking" two windows side by side using the Windows + arrow keys.
              As you can see I've got the casing off (which was quite a struggle) but the thing very solidly built so some way to go to get at the panel which I presume is where the problem lies.
              Any idea if this fixable or shall I put it on menial duties at my office?
              Thanks,
              Nick...
              04-17-2023, 10:26 AM
