Vertical Lines on LG E2211 LED LCD
  • FrankMtl
    • Sep 2015
    • 36
    Could it be the ribbon cable?
    I check the boards and they look fine.
    The lines are there the monitor is connected to a pc or not.
    Thanks.
    Frank.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Vertical Lines on LG E2211 LED LCD
    Failed Lcd panel not fixable sorry.
    • FrankMtl
      • Sep 2015
      • 36
      Thanks, I found the monitor so it's ok.
      Here is a picture of the monitor with ribbon cable disconnected.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Thats because with no power the Lcd falls open (only seeing backlight here, all light let through) and when power is applied the failed tab then loads the lines and cant deselect them due to be shorted.
        • FrankMtl
          • Sep 2015
          • 36
          Thanks, I guess it will go to the E Bin.
          Frank.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            No worries sorry for your loss lol
            • Stanley1843
              Screen Display Vertical Multicolor Lines
              by Stanley1843
              Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
              06-29-2024, 11:54 AM
              by momaka
              03-15-2023, 10:17 PM
            • Falki
              Colorful LCD Vertical Lines on Samsung ue55es8090
              by Falki
              Hello there, ive recently found an older 55inch Samsung SmartTV.
              Sadly it has vertical lines at the left and one line in the middle-right.
              I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
              I have factory resetted the TV as well but also with no luck.
              I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
              A similar issue has been posted as well but also with no actual response ...
              08-12-2025, 04:19 AM
            • visionbluedemon
              Help. Sony kd-65x85dj vertical lines
              by visionbluedemon
              First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
              Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
              tried blocking LC lines too, but same results
              is it lcd panel issue or tcon board issue?...
              07-25-2025, 04:56 AM
            • jackster
              Samsung Curved monitor C27FG70FQU with garbled vertical lines on startup
              by jackster
              I acquired a faulty curved Samsung C27FG70FQU which has the quite common problem of just showing weird vertical lines for a while after a cold boot.
              The issue is pretty bad with this one and it takes about 15 minutes before things normalize and a proper image is displayed. Once a proper image is shown it will work 100% until the display is shut down or put in standby for a while and allowed to cool for a bit.
              Even though this seems to be a quite common issue I haven't really found any information regarding what the root cause is and how to fix it. There is this video...
              02-13-2023, 01:56 PM
