Gateway vx1100 problems
  • buges
    • Jun 2008
    • 3
    Hi
    I've just been given 2 gateway vx1100 crt's, both have faults.
    One will power up just fine, but if i switch it off & on again it wont power up, but if i leave it a couple of hours it will power up. (leaky Capacitor ???)
    The second monitor Just makes a nasty clicking sound & thats it. (Flyback transformer ???)
    Any help would be great.
  • tony359
    Faulty CRT AKF12/Philips CM8500: bad flyback?
    by tony359
    I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
    What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
    There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
    Can it be a short somewhere...
    08-22-2023, 04:39 PM
  • jean luc ferre
    laptop hp g72 b52sf screen problems
    by jean luc ferre
    on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
    the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
    i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
    i don't understand the reasons of the white stripe at the bottom of the screen below the task...
    06-07-2025, 03:27 PM
  • Hondaman
    USB problems?
    by Hondaman
    Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
    (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
    I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
    08-12-2024, 03:26 PM
  • clabr
    Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
    by clabr
    Need help to solve some problems with this laptop.
    After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
    After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
    Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
    Before this had happened I observed some other problems:
    When I tried replacing original mecanical HDD with a SSD HDD could not get them...
    12-02-2021, 08:09 AM
  • retrotechrestoration
    Looking for a flyback transformer for an Eizo TX-C7 MA-791 17" CRT
    by retrotechrestoration
    I just saved this magnificent RGB input Eizo Flexscan TX-C7 MA-791 from the local e-waste...good news, the tube works and the board looks great...the bad news, it sounds like the flyback is shorted. (Turns on...perfect picture...systemic high voltage crackling heard while the picture flickers...then it blows the 5A fuse in my isolated A/C power supply.)
    Anyone have any leads on possibly finding a replacement? (photo shows the flyback model numbers)​...
    03-22-2024, 06:50 AM
