BenQ GW2450
  • Kingdud
    • Mar 2016
    BenQ GW2450
    I don't need help. Or at least I don't think I do. I was going to ask a question about whether NTE caps are 'good enough' for monitors, but I finally found my answer on these forums in the hour it took my account to let me post. *sigh* Anyway, since I have a week to wait while capacitors get shipped to me (all the local stores carry NTE only), and because *nobody* had a cap guide for my monitor, here is one.
    Current caps:
    Pwr converter board:
    --DC section--
    Mfr: Lelon 16v, 680uF, quant: 2, 10mm x 13mm -- Positions C708, C707
    Mfr: FDAI 50v, 47uF, quant: 1, 6mm x 11mm, C712
    Mfr: Elite 25v, 220uF, quant: 1, 8mm x 12mm, C709
    Mfr: Lelon 35v, 330uF, quant: 2, 10mm x 15mm, C703, C801
    Mfr: Elite 100v, 22 uF, quant: 2, 7mm x 12mm, C852, C851
    --AC section--
    Mfr: Elite 480v, 100uF, quant: 1, 42mm x 22mm, C605
    Mfr: FDAL 50v, 22uF, quant: 1, 5mm x 11mm, C610
    I admit I'm not entirely sure if FDAI is, in fact, FDAL. I get more google hits about capacitors with FDAI though.
    LCD board:
    Mfr: FDAI 25v 22uF, quant: 2, 5mm x 10mm, behind VGA connector @ back of board, right of ribbon cable. Both holes.
    Mfr: Aishi 25v 47uF, quant: 5, 5mm x 10mm, all other cap locations
    I measured all the caps myself. That said, my tape struggled with cap height, so if I have down 11mm and you see 10.5 or 12 listed in a guide, assume the guide is correct.
    edit: Oh, and if you were wondering. Mfr: Lelon 16v, 680uF, quant: 2, 10mm x 13mm -- Positions C708, C707 were the caps that failed me.
    • 30983
    Re: BenQ GW2450
    NTE dont make caps - or anything else.
    so it could be any crap they can get cheap.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8697
      Re: BenQ GW2450
      I have a new NTE cap here in my hands...I think the vent looks like a ... TEAPO.
      But yeah it's unfortunate that NTE tends to be readily available. I think most electronics shops that sells replacement semiconductors will sell NTE, and well, the caps come along for the ride.
      Oddly enough I was looking at some of the rat shak parts and though they were all 85C caps, some were actually Nichicons, Rubycons, etc. but yeah still is the luck of the draw, and not to mention they are probably all NOS and not fresh, modern capacitors.
      • seppde
        Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
        by seppde
        I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
        ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
        The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
        In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
        02-09-2024, 05:19 AM
      • AJ847.63e
        BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
        by AJ847.63e
        Hi All.
        Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
        The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
        09-18-2023, 06:42 PM
      • ChatBTC
        Benq EX3501R
        by ChatBTC
        Hi!
        I am new to this site, and found it via LLM ChatGPT.
        I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
        01-24-2025, 08:49 PM
        BenQ JoyBook S52 S53 Laptop Schematic
        Quanta ED3...
        11-01-2024, 02:03 PM
        BenQ S72 Laptop Schematic
        Inventec Grasshopper Rev 3.0...
        11-01-2024, 07:23 AM
