Smd diode code
  • gipiv
    • Nov 2009
    • 12
    • Italy
    Smd diode code
    looking for some help,
    does anyone know the value of these smd's D604, D6655, both faulty ? Are they zener diodes? I've included pictures of them
    They're mounted on the power supply board of a Dell 2408WFP.
    I was wondering also if anyone knows the values of the smd capacitors (which are unmarked)
    C709
    C710
    C629
    C630
    C610
    C609
    C613
    C614
    C627
    C620
    C626
    C624
    C623
    C621
    C628
    (many thanks bicycle6228 for the schematics).
    Many many thanks for any help as I don't have a ton of experience.
    • 31214
    Re: Smd diode code
    they arent zeners, so probably a 1N4148 will work.
    • fzabkar
      • Mar 2009
      • 772
      Re: Smd diode code
      D604 and D655 are shunted by low value resistors. Are you measuring these diodes in-circuit?
      • jetadm123
        • 2169
        Re: Smd diode code
        As stj indicated, they are LL4148 diodes. These type diodes and ceramic caps almost never fail on these power supplies.
        • gipiv
          • Nov 2009
          • 12
          • Italy
          Re: Smd diode code
          Hi
          thanks to all for the replies. Very very appreciated !
          Yes I am measuring them still in-circuit (mea culpa !). I was going to remove them to test again and make sure they are okay.
          Does anyone know of a good reference for the codes of the smd capacitors I could check out to decipher the codes and perhaps complete the schematic.
          Thnaks again !
            LCD LED TV Service Menu Codes
            ALL LCD LED TV SERVICE MENU CODES
            Service Menu Code with Board Name
            China Universal Board / Jumper Board Service Menu Code
            Changhong Ruba Service Menu Code
            Ecostar LED TV Service Menu Code
            Orient LED TV Service Menu Code
            Haier LED TV Service Menu Code
            TCL LED TV Service Menu Code
            Samsung LED TV Service Menu Code
            LG LED TV Service Menu Code
            Videocon LED TV Service Menu Code
            Supra LED TV Service Menu Code
            Toshiba LED TV Service Menu Code
            Symphony LED TV Service Menu Code
            Veste/ LED TV Service Menu Code...
            10-31-2024, 03:58 AM
          • corrize
            What is this component ? smd double diode like, marking code : RX
            by corrize
            Hello, do you know what it is this component marked RX please ? I can't find it. Probably it is a part of serie, because I saw another marked RW....
            10-17-2024, 02:33 PM
          • Curtissimo
            HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
            by Curtissimo
            Hi everyone.
            I have a HP Elitebook 850 G8.
            Serial: 5CG2324XM0
            ProdID 6L8D5EC#ABA
            It has a Winbond W25Q256JVEN Chip.
            I need to remove BIOS Password.
            I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
            Attached my dump.
            I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
            I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
            What I did:...
            08-26-2025, 04:42 AM
          • asr
            Finding replacement diode iPad Pro 3rd gen A1701
            by asr
            Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
            Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
            07-09-2024, 06:24 PM
          • unimatrix93
            TV backlight zener diode
            by unimatrix93
            Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
            So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
            Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
            The led strips has 9 6V leds.
            02-10-2025, 12:13 PM
