Eizo SX3031W Single-Pixel Vertical Lines. Disappear after warm-up.
  • keller1
    • Jan 2015
    Hello! I've got an eizo monitor i'd like to mend, an SX3031W. It has a vertical pixel-line issue. When booted there will be 4 or 5 vertical lines. each missing a chroma key or two. After warmup (20 mins) the lines disappear entirely and are no longer an issue.
    I have not tried anything yet though my suspicion is that it is a loose flex connection to the Panel.
    What would be the recommended course of action be? The monitor is quite nice and i'd hate to replace it.
    EDIT: Almost certain that it is a tab bond failure after checking out the wikipedia article and then searching for tab bond failure.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8225
    Re: Eizo SX3031W Single-Pixel Vertical Lines. Disappear after warm-up.
    you are on the right track.
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Stanley1843
      Screen Display Vertical Multicolor Lines
      by Stanley1843
      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
      06-29-2024, 11:54 AM
    • jeyoung12
      Samsung QN50Q60t lines on screen
      by jeyoung12
      Hi all
      I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
      My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
      This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
      It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
      So....i don't know what end of the C ribbon to work with...
      02-26-2024, 10:38 AM
    • Rubenlily
      Samsung QE50Q67TAU - horizontal lines
      by Rubenlily
      First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
      I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
      I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
      I'm no expert but I've done the tape...
      08-16-2023, 01:12 PM
    • ggil44
      Sony XBR-65X750D Horizontal lines bottom of screen
      by ggil44
      Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
      05-30-2023, 07:51 PM
