asus ve245h random video mode issue
  • xx_ed_xx
    • Dec 2015
    • usa
    Thanks for the great board. Pun intended
    Anyhow I have a video of what my monitor is doing. Wonder if any of you have insight into the matter.
    it seems to be a warmed up issue initially if turned on from being off for a while. it wont do it. Then once it starts it is random.
    I slid the zif cable out of the board for the buttons thinking mebbe that was the issue but obviously not.
    https://youtu.be/kUfBf8JtzgI
    Video may not work right away... still uploading
  • bajdik
    Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
    by bajdik
    I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
    Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
    I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
    Unfortunately, I don’t have access to the schematic.
    It seems to me that when I bend the board, something changes.
    Could this...
    08-13-2025, 07:26 AM
  • MakNCheese
    ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
    by MakNCheese
    I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
    Symptoms:
    • Severe lag across the system, including BIOS navigation.
    • Slow boot times and unresponsive performance in Windows.
    • Battery charges very slowly (e.g., ~5% in 2–3 hours).
    • No error messages or BSODs, just extreme sluggishness.
    What I've Tried:
    • Replaced
    06-04-2025, 12:48 AM
  • ZixuTech
    Asus F1502Z BIOS issue? CPU gets hot but no other response. No blinking light
    by ZixuTech
    Hey guys, I got this model which stays black screen but CPU heats up. All voltages on board seems oK.
    Perhaps BIOS issue?
    Brand: Asus
    Model: F1502Z
    SN: R4N0CV11S622169
    Board: X1403ZA 2.2
    I have flashed this BIOS for test purposes and it lights up the ASUS but blank SN. https://www.badcaps.net/forum/troubl...21#post3593121
    Can you clean and enter SN for me please....
    03-31-2025, 05:04 PM
  • Nicktronic
    Philips 75PFL5704/F7 A Video Issue
    by Nicktronic
    Hey everybody, got a strange one here.
    The TV will display the Home Screen, Menus, Netflix Home Screen, YouTube home screen with preview tiles, etc, without issue. As soon as I try to play video (streaming or from any of the HDMI inputs), all I get is audio and and blank screen. It's like the video is not being processed. So I ordered a replacement main board. I can now play video from streaming sources but the video from HDMI sources is all green (kinda like photo negatives but all green) and the audio does not work. Is it possible the main board I ordered is also failing?? I can't...
    10-31-2023, 05:43 AM
  • ezenia
    ASUS PRIME B450 PLUS (rev 1.02) USB Overcurrent issue
    by ezenia
    So I bought a faulty ASUS PRIME B450 PLUS motherboard off eBay. They said it was water damaged and they cleaned it. The PC POSTs and displays a message that it's detected USB overcurrent and will shut off in 15 seconds. I verified this myself. So I did some checks at the ATX connector 1st to see if the resistance readings looked OK. I found the 3.3V rail measures just 179Ohms which seems way too low. It's been much higher on other AM4 boards I've worked on.
    So I did some Googling to see what the potential culprits are. It varies from bad protection diodes, bad...
    10-18-2025, 05:06 PM
