L1953s with no 5V
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    L1953s with no 5V
    So I got this LG LCD that had the obvious problem - bad caps.
    Changed the caps but for the first time after about a hundred LCD fixes I had soldered one of the caps on the wrong way. That cap just blew up so I changed it for a fresh one, this time correctly.
    Tried it on and... LED light turns on for half a second or so and then just turns off again. Nothing else happens.
    So I took it apart again and saw that there was no 5V present.
    When I disconnected the powerboard from the mainboard, let it wait a little and then connected the powerboard to the AC, there was a nice 5V and 12V was about 16V. Connecting the mainboard made the 5V disappear again and voltage on 12V was dropping about 0.1V per second, doesn't matter if AC was connected or not (so it was just a cap discharging).
    I have tried another mainboard but the problem is still there. I don't have a working powerboard to test the mainboards though.
    Furthermore, I have tried disconnecting the inverter part from the rest of the powerboard by removing J1 jumper. Still the same problem.
    Any ideas what to check?
  • Porto
    • May 2015
    • 109
    • NL
    Re: L1953s with no 5V
    Guess you have a short to ground on that 5v line on the powerboard.
    Maybe in the progress it shorted a mosfet or the driver IC?
    Also check the diodes on that rail.
    Can you post highres pictures of the powerboard's back and front side?
    • Porto
      • May 2015
      • 109
      • NL
      I guess this is the same monitor... here is the service manual of it, with block diagrams and schematics of all boards:
      lg/flatron_l1753s
      • AustinComputerDoctor
        Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
        by AustinComputerDoctor
        I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
        I see backlite is active,
        but I cannot get the screen to return back to menus , etc
        This is all after replacing the mainboard...
        any assistance is greatly appreciated.
        03-25-2024, 12:43 PM
      • Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
        by Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
        03-15-2024, 09:37 AM
      • tec3000
        Sony LED 65X9005A shuts down after few seconds - looking for help
        by tec3000
        Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
        I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
        03-20-2024, 07:29 AM
      • www
        LG L192WS-BN backlight turns off after 1 second
        by www
        I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
        I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
        03-24-2024, 05:26 PM
      • Mirenia
        Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
        by Mirenia
        I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
        I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
        In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
        The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
        03-30-2025, 06:47 AM
