Samsung 710V.
  • Ultrazoom
    • Feb 2008
    Samsung 710V.
    I have 4 of the above LCD Monitors which are having the same problem (symptom) described below.
    When I first power them on with the PC, they all seem to work fine, running at 1024x768. However, if I were to just power off the monitor soon after, then on, or do a restart of the PC, or leave the screen on for some time, the screen simply goes totally blank, black in fact.
    During restart, I could only see the stuffs during POST and the WinXP splash screen. When it goes into WinXP (supposed Welcome screen), nothing is displayed. The Power LED is still showing constant green, and I could hear WinXP's startup sound, and shutdown sound from my speakers if I press the power button on the desktop casing.
    This problem showed up after they are out of warranty. Could anyone advise what could likely be wrong? I thought it could be due to bad caps, but please correct me if you think is not the case.
    I wanted to open the monitor up to inspect, but I don't know how to remove the back of the monitor after removing all the screws. Anyone could advise on this as well? Thank you very much.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Samsung 710V.
    remove the four screws for the base
    remove the base
    remove the two screws under
    find the two tabs at the bottom edge of the screen on the backside, separate there
    there are an additional two tabs on each side edge of the screen, these are not visible, need a 3.5mm flat screwdriver.
    screen opens and "hinges" on the top
    i have some internal pics but no answer to your problem
    https://www.badcaps.net/forum/showthread.php?t=1386
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • Chrissygizmo
      samsung galaxy ao2s very temperamental after screen replaced
      by Chrissygizmo
      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
      Ive eventually managed to get it on and working but it's very temperamental...
      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
      05-26-2024, 12:05 AM
    • Kiberge
      Samsung LH82QENELGC/EN Help needed - Static line on screen
      by Kiberge
      HI guys!
      I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
      I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
      the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
      This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
      04-22-2024, 11:28 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • arbitarytwist
      Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
      by arbitarytwist
      Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
      Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
      03-01-2025, 01:16 PM
