LG Flatron L194WT-SF - 2 seconds to black
  • matthmal
    • Nov 2012
    • 306
    • Malta
    Hi Guys,
    I have an LG Flatron L194WT-SF which around 5 years ago stopped working, I opened it and replaced a bulged cap on the power board and worked fine till now. Lately it started to do 2 seconds to black, the LG logo starts to come up and goes off instantly, I re-opened the monitor and found the remaining caps on the power board all bulged except the one which I replaced 5 years ago.
    I replaced the remaining caps but unfortunately the monitor persisted with the problem.
    Any suggestions please? P.S. I also tried the bulb test and the bulbs didn't turn on.
    Thanks,
    Matt
  • Agent24
    I see dead caps
    • Oct 2007
    • 5038
    • New Zealand
    Re: LG Flatron L194WT-SF - 2 seconds to black
    What do you mean "The bulb test" ?
    -David VanHorn
    • matthmal
      • Nov 2012
      • 306
      • Malta
      With the bulb test I mean that I connected external CCFL bulbs (which I removed from other monitors) and the bulbs still didn't light up
      • Agent24
        I see dead caps
        • Oct 2007
        • 5038
        • New Zealand
        Check the power supply rails are OK and within spec and if anything changes between startup and after the image disappears.
        Did you check with a torch or other bright light shone on the screen to see if the image stays on the screen after the backlights go out, or does the image disappear as well?
        If you still have image, it sounds like an inverter problem.
        Check for bad solder joints on the PCB. I see what could be bad joints on D101, D102, FB102 for example. Reflow any that look suspicious.
        Test inverter transformer drive transistors U304 and U303 for shorts
        Can you give the part number of inverter controller IC U301?
        -David VanHorn
        • matthmal
          • Nov 2012
          • 306
          • Malta
          Hi, I cannot see anything with a torch.
          Any idea of how to test the transistors? searched the internet and it seems like you need a special board. i only have a multimeter.
          the part number of the IC U301 is as follows:
          OZ9938GN
          A6DARU.3G
          0710P
          Thanks for your time,
          Matt
            What DCV do you hvae on the 'ON (BL-ON, or INVER -ON)' pin and the DIM pin, and the 12V pin of the connector J1 of that power supply/inverter board?
            • matthmal
              • Nov 2012
              • 306
              • Malta
              Kindly note the below readings of the J1 connector:
              12V -> 15.4V
              ON -> 0V
              DIM -> 0V
              I also taken the voltage of the big cap, it is 383V, whereas it is rated 100uF 450V.
              Thanks,
              Matt
                12V -> 15.4V
                ON -> 0V
                DIM -> 0V
                Thanks,
                Matt
                If that is what you have when the monitor is turned on and connected to the running PC, then you have logic board problem, it is not sending out the ON (Backlights on signal, nor the Dimming control signal.
                • TVRepairNoobie
                  • Feb 2015
                  • 158
                  matthmal,
                  I have seen one bad CCFL will also result in the 2 second to black issue.
                  Do you have a CCFL tester to make sure your CCFL is good?
                  • matthmal
                    • Nov 2012
                    • 306
                    • Malta
                    Those are with both boards connected to the power but not to the screen and pc, will retake the readings with everything connected. The negative probe should be on the GND right?
                    • matthmal
                      • Nov 2012
                      • 306
                      • Malta
                      Originally posted by TVRepairNoobie
                      matthmal,
                      I do not ave a CCFL tester but usually i connect extra CCFL bulbs that i have, i will retry the test.
                        Yes, without the Video signals from PC most monitor will go into standby mode within seconds.
                        test lamps for testing the board:
                        https://www.badcaps.net/forum/showthread.php?t=19987
                        • matthmal
                          • Nov 2012
                          • 306
                          • Malta
                          Thanks, will retry the tests tonight and will let you know.
                          • matthmal
                            • Nov 2012
                            • 306
                            • Malta
                            I have done the test as you suggested. The attached photo shows that one set of bulbs turn on and the other set tries to turn on with the result that both sets of bulbs turn off.
                            I have re-done the voltage tests as below:
                            12v -> 16.7V
                            12v -> 16.7V
                            GND
                            GND
                            5v -> 5V
                            5v -> 5V
                            GND
                            N.C -> 0V
                            ON -> 3.3V
                            DIM -> 3.3V
                            M/S -> 4.4V
                            Thanks,
                            Matt
                            • ChIck3n
                              Dell u2311h 20000 seconds to black issue
                              by ChIck3n
                              So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
                              09-09-2024, 11:44 AM
                            • DrankinSAW
                              LG 37LG5020 and the tale of 2 seconds to black.
                              by DrankinSAW
                              I bought an LG 37LG5020 with a very strange issue.. it turns on, the display looks fine, but still, after 2 seconds, the TV shuts the backlight off..
                              However, if i leave it plugged in for 20-40min.. the time it takes to shutdown the backlight, doubles (to 4 seconds)..
                              I bought a new inverter, set to arrive on December 13th
                              11-22-2023, 01:10 PM
                              HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                              This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                              09-12-2024, 02:00 PM
                              MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                              This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                              09-12-2024, 01:58 PM
                              Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                              This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                              09-07-2024, 05:00 AM
