DELL E197Fp blown fuse
  • rayfloyd170
    • Jun 2015
    • 58
    • saudi arabia
    I have a Dell E197Fp LCD which has a blown fuse. I replaced it and powered it ON. While powering it up, it showed the DELL Screen display logo but again fuse gets blown (maybe less than 5 seconds after powering it ON.).
    I believe there is a short somewhere but I am just a newbie and all I have is a DMM and a solder. Can you help me what to do first? Which part to test first and how to do it.
    Please be patient with me. thanks
    see sample powersupply board below
  • SteveNielsen
    Retired Tech
    • 2327
    Re: DELL E197Fp blown fuse
    Show a pic of the actual board you're working on.
    • rayfloyd170
      • Jun 2015
      • 58
      • saudi arabia
      okay when I get home, I will take an actual photo of it. thanks.
        • 30985
        both sides of the board please.
        • rayfloyd170
          • Jun 2015
          • 58
          • saudi arabia
          The 2nd pic shows the replaced fuse also gets blown. original fuse is red in color. but i replace with a glass type with same values. Also it was properly insulated with rubberized electrical tape to avoid shorting. In this pics the insulation for the fuse is already taken out.
          the wires below are for the power button board.
          • rayfloyd170
            • Jun 2015
            • 58
            • saudi arabia
            the bridge rectifier is PEC FL406. i dont know how to test it.. hope you can guide me. i also suspect the bridge rectifier (D850). mostly based on what i read this should be tested first. i am not sure though.
              • 30985
              check for shorts between any of the legs on d850 and q850
              and be carefull about your new fuse not touching that metal plate on it's left.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4950
                • New Zealand
                Yes it's one of the first things you should check.
                A bridge rectifier is just 4 diodes connected together a certain way. You can test them individually as you would a single diode by connecting your multimeter to the right pins of the bridge.
                See the attached image for how they are connected inside.
                The DC output pins for positive and negative are marked with + and - symbols and the AC input pins are marked with a ~ symbol.
                Test each diode of the bridge individually to make sure it's OK.
                It's also a good idea to check across the two AC pins to make sure there's no continuity there either.
                -David VanHorn
                • rayfloyd170
                  • Jun 2015
                  • 58
                  • saudi arabia
                  Thanks. i will do this now. But first I have a question. Should I desolder and remove the rectifier diode (D850) and the Q850 transistor when testing it? i guess i need to... sorry for asking too many things.
                  • rayfloyd170
                    • Jun 2015
                    • 58
                    • saudi arabia
                    thanks.. yes, i was putting an elect'l tape on that one.
                    • rayfloyd170
                      • Jun 2015
                      • 58
                      • saudi arabia
                      for Q850, how to check for shorts?
                      hahaha, i just googled it and it is pretty easy.. thanks men.. after work i will remove this two parts and test em.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4950
                        • New Zealand
                        For each pin, check between it and the other two.
                        -David VanHorn
                        • rayfloyd170
                          • Jun 2015
                          • 58
                          • saudi arabia
                          I removed and checked first the rectifier ( + ~ ~ - ) and found out that theres a short at ~ and -. The mutimeter ringer sounded even if i swap the probes from either way. Also when i tried using the diode mode (2k) it really has a 0.01 value both ways i tried it. Is it safe to replace this part first (rectifier) and then try to power up again? Or it would be better to change q850 also. I will still have to source out these parts here and could take some time. Although the rectifier i think would be easier to have
                            • 30985
                            meter q850 just to be sure, you can do it on the board usually.
                            if the rectifier is bad, you may be lucky and not have any other problems.
                            dont forget to get the right type of fuse.
                            • rayfloyd170
                              • Jun 2015
                              • 58
                              • saudi arabia
                              Its good i found a replace rectifier from an old shop and its still working good... For the q850 how to test it? I will check first maybe there is a youtube video for it. Again thanks. I feel excited
                              • rayfloyd170
                                • Jun 2015
                                • 58
                                • saudi arabia
                                Wadahhhh im so happy. It is now working... Really im so thankful to you guys!
                                • rayfloyd170
                                  • Jun 2015
                                  • 58
                                  • saudi arabia
                                  I only changed the bridge rectifier and thats it
                                    • 30985
                                    good.
                                    • rayfloyd170
                                      • Jun 2015
                                      • 58
                                      • saudi arabia
                                      Cheers! Special Thanks to STJ and Agent24 for helping me. This is my very first time to fix a monitor myself with you as my guide. I was determined to fix it because when i go to the shop they asked me $$$$$ and i was not willing to spend either since i already got another Dell monitor as of the moment. Really im amazed coz i spent around 3USD only for the parts...
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4950
                                        • New Zealand
                                        Awesome
                                        -David VanHorn
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • drscoot
                                          HP X360 convertible battery blown fuse error, not charging
                                          by drscoot
                                          HP Modelnumber: 14-dh0061nb​
                                          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                          All these 3 batteries are charging...
                                          12-15-2023, 05:54 AM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
