Dell 2209waf monitor problem
  • rlovison
    • Nov 2012
    • 11
    I'm still fooling around with my Dell 2209waf that I use for photo proofing, trying to figure out a problem that developed a while back. We had a lightning strike that destroyed a few lights and phones. My computer and the Dell monitor were on a UPS backup which is also surge protected but when I checked on the computer, it was froze and needed to be rebooted. Everything worked fine until a few months afterward when the monitor would suddenly dim and color shift toward the red. It was still usable for anything but photo proofing as only the color balance and brightness changed. Usually after a few minutes it would brighten back to normal. This went on for a year or so until finally it dimmed and never came back to normal.
    I replaced the inverter board and there was no change. I took the entire unit apart down to the ccfl's and they all had just a very slight blackening on each end. There is only 8000 hours of use on the monitor. I didn't test any of the bulbs individually.
    Another strange thing is when I bring up a web browser or any program and then close it, there is a ghost of the window remaining on the desktop for a minute or so. Is this the way aging ccfl's behave? I'm just wondering if some chip got damaged on the power supply/logic board during the strike. Any input would be appreciated.
    • 31214
    Re: Dell 2209waf monitor problem
    ghosting is a bias error on the panel usually.
    • Borse2008
      by Borse2008
      • There’s
      07-15-2025, 04:55 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
      by momaka
      03-15-2023, 10:17 PM
    • Jesus Coder
      Issues Reviving Old Dell 2408WFPb Monitor
      by Jesus Coder
      I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
      06-25-2023, 02:33 PM
