Sony CPD 420GS
+ More Options
Posts
  • weirdlookinguy
    • Sep 2007
    • 1638
    Sony CPD 420GS
    Hey everyone, my Sony CPD-420GS (19" CRT Computer Monitor) lost Horizontal Deflection the other day. I can't find any burned resistors or components inside, and I swapped out a few bad caps. Didn't help.
    Can you guys help me? Tossing it and buying another used one or an LCD is not an option. I have the repair manual.
    Thanks,
    -weird
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Sony CPD 420GS
    Check the HOT (Horizontal Output Transistor) with the diode function of your multimeter.
    It will be on a big heatsink near the flyback.
    • weirdlookinguy
      • Sep 2007
      • 1638
      Re: Sony CPD 420GS
      There are two, I will check both. One is a IRFI9634G (Labeled Q901) and the other is a FS7KM-18A (Q902). Q902 is a cross for NTE 2960, I couldn't find any crosses for IRFI9634G. Can you tell me what readings I should get? Neither looks burnt or damaged in any way. Also do you think bad caps could cause this? I've replaced a few bad caps on the neck board and the left side of the chassis, but haven't checked any caps on the right side (side w/ the flyback). Could they be the cause? I ask because I can't get either Q901 or Q902 locally, so I don't want to replace them unless I know for a fact they are the cause of the problem.
      Thanks a ton. I was starting to lose hope on this monitor.
      • weirdlookinguy
        • Sep 2007
        • 1638
        Re: Sony CPD 420GS
        OK, Q902 looks to be bad. I googled how to test transistors and on a normal transistor, you should get a value (like 0.980 for example) when you test it one way and no conductivity when you test it the other. On Q902 (FS7KM-18A) I get 0.908 one way and 0.600 another, according to the guide I read that is bad.
        One thing though, the schematics in the repair manual clearly state Q902 as being a FS7KM-18A. The Q902 that's actually on the board is a FS5KM-18A. Does it matter which one I replace it with? FS5KM crosses to NTE 2959, and FS7KM crosses to NTE 2960.
        Are there any other replacements I can use? I pulled apart an older 15" Trinitron but to my dismay there was no FS7/5KM in there. I can't get NTE 2959 or 2960 locally, all I have is Radio Shack and Fry's. Fry's stocks a lot of NTE but they don't have anything in the 2900 range. I's rather not buy anything online, buying online is nearly impossible for me.
        EDIT: According to this: http://www.anatekcorp.com/faq/monitor.htm, Q901 and Q902 drive the flyback in a Dell P991, which uses the same chassis as my monitor. I still have HV, just no horizontal, so Q901/Q902 can't be the problem, right?
        • weirdlookinguy
          • Sep 2007
          • 1638
          Re: Sony CPD 420GS
          OK, big update: The HOT is a Hitachi 2SC5530-01, Part # Q505 inside the chassis. It is SHORTED, according to my multimeter. I'm pretty sure this is the source of the problem. The only problem now is finding a replacement. There is no NTE cross for this. I doubt radio shack will have it, and I don't think Fry's will have one. I must buy locally. Can you suggest a replacement? Also I have a 15" Trinitron monitor made in 1996 (the 420GS is a 1999 model). Do you think it will have the same HOT, maybe I can pull it from there?
          Thanks a lot, waiting on your reply.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            Re: Sony CPD 420GS
            where are you?
            i know i have gotten these from cei
            www.ceitron.com
            they are local to me and great to deal with.
            be warned that there is abuck converter that feeds the h-out stage that will have a shorted fet.
            you MUST repair it or the new hot will die in seconds.
            also resolder the h-drive transformer.
            that seems to be the most common cause of hot death.
            • tvtech
              • Oct 2006
              • 48
              Re: Sony CPD 420GS
              Kc8's right there will be another shorted fet,I forget on which heatsink the fet was on,Try not use any NTE replacements for power trans. or FET's they don't last very long,go with an original part.And since your HOT is shorted it may be a good idea to check the flyback for burns or signs of arcing,look close to where the anode lead exits the fly.Also do as suggested and resolder the HDT and connections surrounding it.As for pulling the HOT from your other monitor,Probabaly not as it may be a different chassis but you can check.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                Re: Sony CPD 420GS
                the fly on these is driven independant of h-out.
                and nte is not much better than the crooks that remark lesser speced parts for a quick buck.
                its surprising how many counterfiet parts are out there.
                warning signs can be a too good to be true price on an expensive or hard to find part.
                large monitor hots and stk's top the list.high power audio and rf transistors not far behind.
                • weirdlookinguy
                  • Sep 2007
                  • 1638
                  Re: Sony CPD 420GS
                  The 15" Trinitron did not have the part. It was unlikely that it would but it was worth a shot. Anyway, I have found the HOT online:
                  http://www.bluestar-online.com/2SC55...FQ6NHgodr0oAFQ
                  I don't know if it's an original. I've bought stuff from these guys before and they are trustworthy. I didn't mention this before, but before it died, the image kinda flinched a few times every few minutes before it gave up. Immediately after Horizontal collapsed, I shut off the monitor. Upon turning it back on, the vertical line would appear for a second or two before the monitor shut itself off and the power line started blinking. Now, I don't get the vertical line, but that's probably because the tube doesn't have enough time to warm up before the monitor shuts off. Do you guys think that points to bad soldering on H Drive, shorted FET, or is it insignificant?
                  • tvtech
                    • Oct 2006
                    • 48
                    Re: Sony CPD 420GS
                    Yes probabaly shuts down before the tube can warm up.Yes you probabaly have bad connections and that was causing you to lose deflection,I would inspect the entire horizontal section.Resolder the drive transformer and carefully inspect all other conections in the horizontal section.Don't be surprised if you have to resolder almost every connection,some of the older sony tv's and studio monitors I worked on I had to resolder nearly all of the connections in the set,especially the studio monitors that had run 24/7 for 7-10 years due to the heat.As for the replacement transistor you found,iv'e never heard of that reseller before but they look reputable,but I would browse around and see if you can find the original hitachi part first.The worst part is about the bogus parts is that most of the parts suppliers that sell the parts to you dont even know that they are knockoffs.The best way to know if you have an original part is look at the markings,most of the major japanese manufacturers,st,toshiba,hitachi,fairchild will laser etch the part number and their logo or name on the part not use an ink stamp.BTW-kc8 what kind of python is that in your avatar?
                    • weirdlookinguy
                      • Sep 2007
                      • 1638
                      Re: Sony CPD 420GS
                      I think I'm going to have to go with the bluestar one, I really didn't want to have to order online since I have to get my dad to order it for me, but I am going to try and see if I can send them a money order or something. I don't know if it's an original but right now it looks like it's the only one I might have access to. I will replace and resolder everything, as well as check any FETs I can find. FET's are three-pin devices on heatsinks that look similar to the HOT, right? There's one right next to the HOT.
                      • tvtech
                        • Oct 2006
                        • 48
                        Re: Sony CPD 420GS
                        Yes FET's are three pin transistors and are usually mounted on heatsinks,just check the large transistors on the board or that are mounted on heatsinks,dont worry about the small half-circle shaped ones yet.As for trying to find your FET I may have a good used one here as I have scrapped some newer sony CRT monitors due to obselecence and may have saved the HOT from them.Here I couldn't even get 10-15 dollars for a 19" CRT monitor so most of them get scrapped.
                        • weirdlookinguy
                          • Sep 2007
                          • 1638
                          Re: Sony CPD 420GS
                          I appreciate that tvtech. I'm leaving on a two week vacation in a couple hours, so I won't get back to this monitor until after new years, but I will revive this thread once I get back. Thanks a lot for the help everyone, talk to you in 2 weeks.
                          • weirdlookinguy
                            • Sep 2007
                            • 1638
                            Re: Sony CPD 420GS
                            Well guys, looks like it ends here. When my dad found out it would take $20 to (maybe) fix the Trinitron, he told me to trash it and offered to help me pay for a new LCD, if I get decent grades and use some money saved from my summer job. I tried to convince him to let me fix the Trinitron but he said he wouldn't let me keep pouring money into a nearly 10 year old monitor (I already put about $20 worth of new caps into it). I wasn't really convinced at first but I found this really nice HP at Fry's that I really liked. Looks like I'll be scrapping the board, saving the new caps I installed, the flyback, coils, etc. Kinda sad but at the same time I wouldn't mind a 16:9 display, so...
                            Thanks for helping me try to save this monitor.
                            • motorahead
                              Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
                              by motorahead
                              Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
                              After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
                              10-21-2023, 03:50 PM
                            • Carlos#2003%
                              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                              by Carlos#2003%
                              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                              02-15-2024, 07:52 PM
                            • dkneyle
                              Sony KDL-46HX850 Can't upgrade/update firmware
                              by dkneyle
                              Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                              Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                              09-25-2024, 10:44 PM
                              Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                              This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 05:27 AM
                              Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                              This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                              09-06-2024, 05:30 AM
