How to identify capacitor function?
+ More Options
Posts
  • goop
    • May 2014
    • 45
    • state
    This was from another thread:
    Originally posted by budm
    This is monitor power supply, not critical. Is this for the startup/running cap?
    How can you identify the function? What are the typical circuit stages?
    Re: How to identify capacitor function?
    You have to work on lots of circuits and boards to learn how to identify each section of the board.
    • goop
      • May 2014
      • 45
      • state
      Can you recommend something to read for an overview of common PSU or LCD PSU designs, maybe walkthroughs of some specific existing PSUs?
      That capacitor you asked about was a 33uF 50V low ESR in the primary side, with 12-13V across. There's only one another electrolytic in the primary, a 0.47uF 50V standard impedance, with 1.6V.
        Since we have no ideas which power supply board you have, it will be impossible to tell you what caps are for what.
        How about providing some more info and good pictures. Board lay out of each power supply boards are not the same but they do have same common building blocks, to narrow down to component level is another story which you will need good basic back ground of the components and how they work and how they are used, good theories in basic electronics, then you need basic understanding of the power supplies which come in more than one form.
        Do the search for switching power supply, linear power supply, etc.
        Doing the repair without the diagrams is a lot more difficult.
        You can download some training manuals and service manuals here for studying.
        WWW.ELEKTROTANYA.COM
        Search example :SONY TRAINING
        http://elektrotanya.com/?q=showresul...at2=schematics
        You will see lots of info.
        • goop
          • May 2014
          • 45
          • state
          I thought since you had a guess for the function of the capacitor in that quoted post, a few more details and you would be able to tell with certainty what it is for.
          The PSU works now. I was just curious about what you said.
          Someone uploaded shots of this specific PCB before. It's C103, the bottom one:
          https://www.badcaps.net/forum/attach...5&d=1319653243
          https://www.badcaps.net/forum/showthread.php?t=17123
          And you referred to this cap and its sibling in a very similar board:
          https://www.badcaps.net/forum/showth...026#post230887
            First link: C103, C105 those are small value startup/running cap, they are for filtering for the DCV feeding the VCC pin of the SMPS IC. It does not have to be super low ESR due to not very high current demanding by the circuit.
            Third link: same function.
            If you look up the spec sheet of the IC then you can see how they are used.
            The AUX winding of the transformer provides the running Voltage ones the circuits starts running (the cap is first charged up the charge pump circuit inside the IC, when the Voltage reaches the Vstart threshold, the IC then start driving the power MOSFET which drives the power transfomer), this Voltage from AUX winding is also used to run other circuit such as the PFC IC, the SMPS IC of the main supply. That is the typical setup.
            • goop
              • May 2014
              • 45
              • state
              So that IC runs on 12V? What's the 1.6V for? If low ESR isn't required, did they use it just because of stock or price concerns?
                • 30953
                low esr caps generally last longer and people like me dont want to stock crappy caps when we alerady have the same values in low esr stockpiled.
                  Which IC P/N? each one has its own operating range and also it sown startup Voltage, you need to look up the spec sheet to see, if the VCC is high enough to run the IC bit it is still dead then you need to find out why.
                  The ESR requirement of the cap depends on the circuit and for this section it does not require super low ESR like what are used in the mother board, it should be LOW ESR but not super low as required by mother board.
                  You can also do experiment using decade box to put resistor in series with the low ESR cap to simulate HIGH ESR and see as to how high the ESR can be until the circuit stops functioning.
                  Look up the spec sheet of the IC used in your board, you will see the application notes and the circuits.
                    BTW, the 0.47uf may be for the feedback circuit around the receiving (PHOTO TRANSISTOR) side of the OPTO.
                    • goop
                      • May 2014
                      • 45
                      • state
                      If it can work well, sure. But I guess some circuits may rely on having a certain ESR range.
                      budm: Thanks.
                      Can't check the IC model directly anymore.
                      Regarding adding external resistance, won't it require a more extensive analysis to tell for sure how a higher resistance affects the circuit? For example, it might seem functional superficially, but will have latent side effects. More noise, components that are driven harder, etc.
                      What's the function of the optocoupler?
                        • 30953
                        optocoupler is feedback to control the output voltage.
                        what do you REALLY want to know?
                          "Regarding adding external resistance, won't it require a more extensive analysis to tell for sure how a higher resistance affects the circuit? For example, it might seem functional superficially, but will have latent side effects. More noise, components that are driven harder, etc" That is why it is the experiment you need to do to see it for yourself what affect of high ESR will do to the circuit. How else will you learn?
                          "What's the function of the optocoupler?" Seem to me you need to learn more about electronics component and its function. Do the search on the internet if you really need to learn, like I said, download the schematics and see how it is done.
                          Want to learn more?
                          https://www.badcaps.net/forum/showpo...&postcount=179
                          • goop
                            • May 2014
                            • 45
                            • state
                            stj: Just a better understanding of the above PSU, and similar ones.
                            budm: For a useful experiment I'd first need more knowledge.
                            I didn't mean the general function of an optocoupler, but its role in the specific circuit.
                            Anyway, all right. I'll proceed to unguided reading. Thanks for the PDFs.
                              • 30953
                              get a datasheet for the controller chip the psu uses.
                              it will have operational descriptions etc.
                              • goop
                                • May 2014
                                • 45
                                • state
                                I suppose when you have enough experience, you can infer or guess the function without tracing connections and reading datasheets.
                                • BlackBurn
                                  Help to identify a laptop mainboard SMD capacitor LA-9982P
                                  by BlackBurn
                                  I have an Dell Inspiron 15 3537 laptop mainboard (LA-9982P Rev. 3.0 (A02)) with a blown SMD capacitor as shown in the attached images. However, there is no printed specifications near the capacitor or a codename for the capacitor to identify the specification of the capacitor to replace it. I wonder how to identify the capacitor since the mainboard schematics are also useless as the capacitors are not named on the board. Any help would be highly appreciated.
                                  Thank You. Stay Safe.
                                  Chamara...
                                  11-27-2020, 08:30 AM
                                • chth96
                                  If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                  by chth96
                                  I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                  Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                  It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                  So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                  I know that these capacitor will not last as long as nichicon capacitor...
                                  12-22-2023, 04:34 AM
                                • chth96
                                  How can I test non-polarized capacitor?
                                  by chth96
                                  I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                                  I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                                  And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                                  I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                                  06-02-2024, 07:31 PM
                                • chth96
                                  Is it no harm to replace with capacitor without ripple current rating?
                                  by chth96
                                  When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                  Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                  But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                  Rubycon YK DataSheet (b...
                                  04-19-2024, 05:19 AM
                                • chth96
                                  Should I replace polymer capacitor?
                                  by chth96
                                  a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                                  I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                                  Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                                  Is this ESR value of polymer capacitor correct?...
                                  11-18-2022, 04:22 AM
