Dell 2007FPb intermittently turning off
  • omegat
    • May 2015
    • Ireland
    I have a Dell 2007FPb that over the past several months intermittently turns off. It will turn on again immediately and last for a few seconds to a few hours before switching off again.
    What does that sound like? Perhaps a voltage droop? I haven't pulled it apart yet as the monitor keeps working (mostly)!
  • tommy_b
    • Feb 2015
    • 11
    Re: Dell 2007FPb intermittently turning off
    Could be caps starting to go bad, usually on the power supply board or inverter board. But really, it could be a lot of things. Checking/replacing the caps is probably a good place to start though (if you're inclined to open it up and spend time working on it).
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • elzorroazul777
      [Troubleshooting] Dell T7610, computer won't post after turning on memory mapped IO >
      by elzorroazul777
      I have a Dell Precision T7610, 2 Xeon 2650 v2, 128Gb of ram, MB NK70N. Bought off of ebay in December and shipped with 1 processor and 64 gb of ram. I recently filled the other side of the board with processor #2 and 64 more Gb of ram. There are two gpu's, Nvidia K420 for video and Nvidia P40 for accelerated graphics. I have shelled out my entire budget on electronics tools and building this ‘homelab' computer. I do not have the money to buy another motherboard at this time, otherwise I would!
      The motherboard that shipped with the computer needed replacement as socket #2 wasn't...
      02-14-2023, 09:57 AM
    • ckom26
      Dell 2007FPB compatible boards
      by ckom26
      Hello, folks.
      Please, forgive this dumb question but I own a 2007FPb whose logic board is FUBAR (really). Obtaining a replacement is not easy any more (or unreasonably expensive) so I was wondering if replacing the logic board with one from the same line (e.g. 1708FP or 1907FP) would bring it back to life. Are the resolution capabilities for each one "hardcoded" into the main GENESIS chip or auto-sensed and applied? Has anyone tried something similar?
      07-04-2025, 07:02 AM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
