Samsung T260 No power. No Power Led turning on
  • psm21
    • Mar 2015
    • 5
    Hello guys, hope somebudy here can help me or atleast with some advices. I have one Samsung T260 monitor which looks dead (no signs of life at all, no lights, blinks, no reaction to power btn) looks like I didn't pluged it into power line. I should mention that my knowledge in electronics is not deep enought but I have some basic understanding how electical circuits works. So I decided the problem is in Power Supply.
    I have already checked some topics here about same monitor or related, but my problems sims to be a bit different. At first I have checked powersupply visualy: no signs of damaged capacitors (leakages, deformations,....) or other elements (no signs of High Temperature...), everything looks like totally new! (checked it 3 times with flashlight. Also measured some resistances and voltages as was recomended in other related topics, here the measurements:
    Input: 220V
    Output 14PIN:
    P2=15,02V
    P6=5,26V
    P7=5,26V
    P10=0V (Instead of 3,3V also no reaction on PWR BTN)
    Main Fuse: 01,2 Ohm (Looks OK)
    F301=01,3Ohm
    R301=384KOhm
    ZD101=725/1075
    ZD102=676/1(Out of range)
    D106=676/1(Out of range)
    D102=629/1(Out of range)
    D103=161/161 (????)
    D107=830/1(Rising from ... up to 1 Out of range)
    R103=01,6Ohm(Not sure it will be the same out of circuit)
    C101=~227V
    C102=~227V
    C103=~227V
    C104=0V
    C105=313V
    C106=1,83V
    C109=11,34V
    C117=108V
    C118=3,98V
    C119=5,26V
    C112=15V
    C108=15V
    C113=5,26V
    C116=5,26V
    C114=0V
    C316=15V
    C317=15V
    C301=0V
    C302=0V
    C304=0V
    C306=0V
    C303=0V
    C305=0V
    Also T301 looks fine 1048/1060
    Any ideas? Tell me if you need me to make some aditional tests. Many thanks for your attention!
  • psm21
    • Mar 2015
    • 5
    Re: Samsung T260 No power. No Power Led turning on
    Now it looks like all of output voltages disapeared for some reasons, power is still connected and C105 is still about 300V
    • selldoor
      Slow Learner
      • 7870
      On the back of the board IC101 at the bottom of your picture looks a bit burnt - is it.
      Also just below the large heatsink in your picture there is a green pico fuse.
      What is the voltage on each end with respect to ground screw.
      • obex
        • Oct 2014
        • greece
        same here, no voltage on 3.3 volt, i am getting negative voltage -0.202
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • mrtek
          Samsung UN43NU6950FXZA No power
          by mrtek
          Hi
          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
          Main fuse = OK
          Back light LED = OK. Power them with aux power source
          LED output = OK 156V
          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
          07-20-2025, 08:06 PM
        • Journey11
          Samsung TV won't turn on ... keeps cycling the power relay on & off
          by Journey11
          Hi All,
          First time posting here ... my name is Kevin but my friends call me Journey.
          I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
          After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
          It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
          07-04-2024, 02:44 PM
          by sam_sam_sam
          03-31-2024, 02:12 PM
        • cheeky2
          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
          by cheeky2
          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
          06-15-2025, 05:12 AM
