Hanns.G HL272 overheated SMPS
  • patrikf
    • Feb 2015
    Hi all!
    I'm trying to fix a monitor that generally works, but has extremely low intensity backlight (on max setting it's extremely weak, in lower settings it flickers).
    This monitor uses LED backlight.
    Looking at the power supply, there is one obviously overheated component. There is also quite a lot of dried fluid type stuff in various places on the PCB (electrolyte?).
    The overheated component is some kind of voltage regulator I think, labeled "S20N10". I'm sure there must be a less obscure equivalent somewhere, but I have not been able to successfully find any specifications on S20N10.
    Anyhow, I suspect it overheated as a consequence of something else going bad. Prime suspect right now are the smoothing caps on the primary side of the transformer, as I can't see any smoothing going on there at all. (But SMPSs are a bit cryptic to me.)
    I've got a few measurements and photos which I will post soon.
    BTW, this same monitor has a thread here:
    https://www.badcaps.net/forum/showthread.php?t=39618
    but it looks like a different problem, and I didn't want to thread jack.
    I appreciate any help I can get!
    Cheers
    Patrik
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4287
    • Italy - Milan
    Re: Hanns.G HL272 overheated SMPS
    "There is also quite a lot of dried fluid" please post picture of that.. can be normal glue..
    "The overheated component is some kind of voltage regulator I think, labeled "S20N10" "
    seems a marking of a double fast diode, if it is it can be normally hot, depends how much, how many seconds you can touch it? It's maybe possible of a too much high voltage due to bad caps or bad feedback.
    "Prime suspect right now are the smoothing caps on the primary side of the transformer, as I can't see any smoothing going on there at all."
    Can you explain this in other words? How do you see the smoothing, oscilloscope? Usually there's a 400v one and a 50v , which one you measured?
    Bye.
      by momaka
      03-15-2023, 10:17 PM
    • ant3202
      HP 27es - LED monitor - Monitor Flashing On - Off
      by ant3202
      Hi Everyone
      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
      https://www.badcaps.net/forum/troubl...lashing-on-off
      The monitor is HP 27es LED Monitor
      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
      The monitor will randomly blackout and display no signal and will recover again.
      Sometimes need to power and off again to restore the display but...
      03-20-2025, 07:30 PM
    • Rick_1234
      by Rick_1234
      Good evening, gentlemen.
      Things I tried
      06-22-2024, 04:44 PM
      Wise Wing F199 19'' LCD monitor - recapped
      by momaka
      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
      When I saw the Craigslist post, I wasn't...
      08-24-2020, 10:58 AM
    • sew333
      Pc shutdown, monitor flickered with no signal after 10 seconds
      by sew333
      My pc:
      10850K stock 4800mhz stock Kraken X73 good temps
      2x16 GB DDR4 GSKILL 3000mhz XMP
      Seasonic Tx-850 Ultra Titanium
      Gigabyte Rtx 3090 Gaming OC
      Aorus Z490 Pro Gaming
      1 TB SSD
      4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
      Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
      Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
      Power...
      02-22-2022, 10:27 AM
