Samsung 2493HM Monitor Fuse
    Hi everyone.
    I'm pretty new here. This site seemed to have the best community, so i joined here.
    I recently received a monitor that I wanted to fix up. The 2493HM Samsung. There's been a lot of posts here, about the capacitors but when I opened up mine, the caps were nice and pretty. The monitor itself is has been lightly used, so I was wondering about a few things
    -Previous issue: monitor LED flashing- Bought new caps(in transit right now) but after opening it up(and finding the caps looking fine) and putting it together it the LED stayed solid so I assumed it was the inverter board. I checked the board and found that the fuses were blown.
    TL;DR
    Does anyone know where to find the fuses for this monitor and the process of replacing them? (i'll look around the forums for fuse replacing)
    Heres the imgur link: http://imgur.com/a/aVyen
    Re: Samsung 2493HM Monitor Fuse
    Are you talking about the white body fuse rated at 7A 125V or the black capacitor to the left of the fuse? Did you check the resistance of the fuse?
    BTW, those yellow glue should be removed it is too late and causes damages.
    https://www.badcaps.net/forum/showthread.php?t=34692
      I have removed some of the glue which resulted in the LED going solid Blue.(from flashing led)
      But here i have some pictures of the inverterboard
      Here take a look
      Imgur link: http://imgur.com/a/F4wzC
        So the white fuse is OK or not? And do you get 24VDC at both ends of the fuse (black meter probe on chassis) when monitor is turned on?
          Hi thanks for waiting. I had some programming to do before i had time.
          The fuses are ok, do you think it might be the transistors(mosfets). Im gonna use the post here to test them but from what the inverter board looks like, they look shorted out. Any chance I could replace them individually or should I just get a new inverter board?
            If the fuse is not blown then the MOSFETs may be OK, but you might as well check the Source and Drain pins of the MOSFET to see if it shows low resistance or not.
            If the inverter board is not connected, do you get 24VDC?
