Dell 2005 FPW 2 and power flashing
  • Nightwolf
    • Mar 2015
    • 52
    Re: Dell 2005 FPW 2 and power flashing
    Originally posted by budm
    6-pin device U612 si3865, is the on/off pin fluctuating so the output will be fluctuating too.
    So need to find out why the control pin is going up and down.
    Do you have the link for the diagram or you can just upload it.
    Here is the service manual with schematics.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4951
      • New Zealand
      I'm not sure but I don't think that is a regulator, unless they are using it as one somehow.
      That device to the right of it in the photo with 1117 on it, that will be a regulator.
      -David VanHorn
        It is electronic switch FOR 3.3V for 3.3c DVI.
        I wonder if other ON/OFF signals for U602, 603, 611 as shown in the manual are also fluctuating.
        • Nightwolf
          • Mar 2015
          • 52
          Yes it is.
          • Nightwolf
            • Mar 2015
            • 52
            U606, U608 and U610 are the regulators and they all put out 3.3v.
            The 3.3_SW comes from the display processor.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4951
              • New Zealand
              #26
              I wonder if U402 is in some reset loop?
              Check PWR_RSTN from R451 (should be near U405)?
              -David VanHorn
                So some how the processor outputs are cycling on and off for other switches as well then.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4951
                  • New Zealand
                  #28
                  Oops. Yeah that doesn't make sense, does it? Then at least U603 would also get switched and U610 would not produce steady output... Never mind then.
                  -David VanHorn
                  • Nightwolf
                    • Mar 2015
                    • 52
                    R451 is 2.19 to 4 9v
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4951
                      • New Zealand
                      #30
                      Wait, so the voltage on R451 IS fluctuating?
                      What do you get on Pins 1 and 3 of U405?
                      -David VanHorn
                      • Nightwolf
                        • Mar 2015
                        • 52
                        pin 1 is 5v, pin 3 is fluctuating. Q401 base .65v, C.028v
                        Q403 C .002 - .005v
                        • Nightwolf
                          • Mar 2015
                          • 52
                          Not sure R450 is in the circuit.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4951
                            • New Zealand
                            #33
                            Possibly, it has a star next to it in schematic which could indicate it is unused. Sometimes they design things in and then don't use them in production, or it's for a different model.
                            Can you remove R451 and see if the output voltage of U405 becomes stable?
                            -David VanHorn
                            • Nightwolf
                              • Mar 2015
                              • 52
                              That's going to be a tough one. Think my iron is way too hot for that SMT resistor. My have to take the board to work and use the hot tweezers on it. It looks like a 0 ohm part too.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4951
                                • New Zealand
                                #35
                                You could try disconnect Pin 3 of U405 instead? It might be easier, they say it's a TO-92 package in the manual.
                                -David VanHorn
                                • Nightwolf
                                  • Mar 2015
                                  • 52
                                  Sorry haven't had time to do either of these thing yet, working crazy hours. Should be able to do in the morning and let you know what I find. Thanks for all the help so far.
                                  • Nightwolf
                                    • Mar 2015
                                    • 52
                                    OK. With R451 removed, one side reads 4.98v and the other side reads ov. Also with it removed, all four 4 lights (1 2 3 4) and the power light is on solid.1 and 2 are yellow, 3 and 4 are green and the power light is yellow. When I read the 0v side, all lights go out. When I remove the meter lead, the 4 numbers come back on the same way but the power light does not come on until I unplug it and plug it back in.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4951
                                      • New Zealand
                                      #38
                                      Seems like either U405 can't handle a load for some reason, or perhaps the reset pin on U402 is bad. Unless budm has any other ideas, it's all I can think of.
                                      What resistance do you get from the 0v side of R451 to GND?
                                      -David VanHorn
                                      • Nightwolf
                                        • Mar 2015
                                        • 52
                                        I get an open to ground. Also where does that signal (PWR_RSTN) go? I tried looking for it but haven't found it.
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4951
                                          • New Zealand
                                          #40
                                          It goes to the /RESET pin of the U402 IC.
                                          -David VanHorn
