Viewsonic VX2835WM
  • Drellis
    • Mar 2015
    • 10
    Viewsonic VX2835WM
    This display took a while to fail. Would have to press power button multiple times to get it to turn on. It finally stopped working all together. Seemed like a power supply failing, so in searching for a replacement power supply, and some troubleshooting information I found the world of bad capacitors which eventually led me here.
    I tested the power button, and it functions properly. All my caps look good, which as I understand doesn't really mean much so I thought I'd post pics of the boards, and get your opinions on what additional testing/troubleshooting I should attempt before ordering and replacing some/all of the caps to see if I can resurrect this display. I've included shots of the main board as well.
    It's a difficult aspect ratio to replace, so getting it working again would be awesome, as it's by far my preferred aspect ratio to work in.
    Thanks for the advice, and all the help you do for everyone on this forum. It's incredibly impressive.
    • 30955
    Re: Viewsonic VX2835WM
    i fucking hate that type of design, the psu just gets cooked!
    from the foto the 2 1000 uf 35v caps are gone, the tops are rounded slightly.
    i recommend replacing *all* the electrolytic caps on that psu.
      https://www.badcaps.net/forum/showthread.php?t=11329
      Same power supply as used in HANNS-G
      • Drellis
        • Mar 2015
        • 10
        That's interesting… They looked fine to me. Any way for you to indicate what tipped you off? I'd like to be able to identify bad caps better in the future if I can. Also would you include everything under the heat sync that's soldered to the board? Specifically the 420v 150hf cap?
        Also: Do you think this is because of shitty caps, or bad PCB design? I have no idea what to expect out of this hardware after I (hopefully) get it working again.
          • 30955
          the top of caps should be dead-flat, look at the top of the big ones in the 4th pic.
          it's a bad pcb design, caps should not be next to or under heatsinks or close to hot parts.
          that design is a joke, they just packed it all in as tight as they could!
          as for the 420v cap, normally i would ignore the main cap, but being under a sink, i'd meter it.
            • 30955
            btw, there are a few bad solder joints on the psu, and the main board also has caps right up against regulators that will cook them!
              by sam_sam_sam
              03-31-2024, 02:12 PM
            • dragon3x
              >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
              by dragon3x
              Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
              that is still quite new, as it worked OK for some months until it failed.
              At the time I was not into power supply electronics; it was put
              aside and a new power supply installed inside the computer. Also at the time
              power supplies were half the price of today's.
              On the PCB there are a D339 and 7500B chips.
              I have found that schematics with these 2 chips (see included file).
              Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
              Some measurements,...
              06-05-2024, 03:34 PM
            • MtnManMike
              Samsung UN75J6300AFXZA LCD TV Power Supply Troubleshooting
              by MtnManMike
              I'm hoping to get some help figuring out how to troubleshoot this power supply board. The television is a Samsung UN75J6300AFXZA, version no. UH03. The power supply board has two model numbers on it, L75S1 and BN44-00723C. As far as experience level, I'm familiar with recapping boards in terms of safely going through the soldering motions, choosing suitable replacement parts, and so forth, but as far as understanding the various functions of each part of these TV power supply boards, I am a rank beginner.
              When I plug the TV in, the screen flashes on and off and...
              07-23-2022, 06:43 PM
            • Zippie
              Troubleshooting Old Chiefmax 650Watt ATX Switching Power Supply
              by Zippie
              I’m looking for some advice troubleshooting an old Chiefmax 650w power supply in a PC, if it’s advisable to dig into it.
              Worst case I can replace the PSU, I’m just interested in learning the troubleshooting process. However, it’s out of my area of expertise and I could use some direction.
              During PC operation I heard a loud pop noise, like a cap gun and the tower lost power.
              Initially there is no power output 3.3v, 5v, or 12v when jumping the power on pin to ground. Also, no fan power.
              Opening the PSU the only things visible initially...
              03-07-2024, 07:58 PM
