Digimate L-2231wd flashing/strobing screen
  • chaseruk
    • Feb 2015
    • avon
    hi all,got a Digimate L-2231wd lcd monitor and for approx 30min works fine.
    After this time,the screen will flash white only for a fraction of a second(strobe-like).
    Then all is well again until the next flash.
    They start out approx 1-2 min apart but after the monitor has been on or 40min or so
    the flashes are much more frequent,maybe 1-2 sec apart.
    if the monitor is switched off,then back on again, the flashes slow down for a couple of minutes
    then back to 3-4 seconds apart.
    The monitor has a Emax e59670 power/inverter board.There were a few bulging caps which i replaced
    but this has not had any effect on the problem.
    I have noticed that when the flashing starts,the area around the power/inverter board gets very hot,
    much hotter than any other monitors i have.
    Could this be a heat related problem ?
    I do not know what to look for/inspect next.
    Any help greatly appreciated.
    Thanks.
    Paul
  • chaseruk
    • Feb 2015
    • avon
    Re: Digimate L-2231wd flashing/strobing screen
    Quick video of the problem here,this was after approx 15min
    http://youtu.be/0dyGTNQPR3k
    • HTR-Informatique
      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
      by HTR-Informatique
      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
      I also changed the screen because the PC fell and the screen was broken.
      I changed the battery with a new and original battery.
      I also had corrosion/oxidation on the...
      02-09-2025, 06:51 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • dbuergi
      Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
      by dbuergi
      i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
      Any ideas where to look?...
      11-07-2024, 10:57 AM
