Dell 1905 fp
  • fc227a
    • Jan 2015
    • 12
    Dell 1905 fp
    Greetings all,
    After fixing the Acer 1716 , The Dell 1905fp decided it did not want to play and turns the screen black after a few seconds.
    Question, how do you get the back panel off ?
    God Speed , Fred
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • F R 2568
    Dell Latitude 5420 does not start (no post) need help to find the reason why
    by F R 2568
    Hello all,
    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
    If the laptop is only connected to the AC adapter (battery removed):
    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
    The power/battery...
    01-08-2025, 05:45 AM
  • diamon
    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
    by diamon
    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
    Pictures of these boards:
    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
    Dell...
    02-28-2024, 12:51 PM
  • lalle-
    Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
    by lalle-
    Hello!
    I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
    [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
    I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
    The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
    I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
    08-11-2024, 02:01 PM
