LG Monitor L19NT-A with interference on screen help
  • ivtec
    • Dec 2008
    • 1967
    Hi guys; I already posted in the computer forum but did not get any tips on this Monitor issue, may this is the right place to post this issue!
    I send new Pic how this intermittent fault goes away by pressing 2 fingers against each other in the middle top edge of the panel.
    Any help would be appreciated
    https://www.youtube.com/watch?v=l2v7J3785Cw
    • 12276
    • U.S.
    Re: LG Monitor L19NT-A with interference on screen help
    not sure but that's the same symptons you get with loose tab bonds on some lcd tvs.
    • ivtec
      • Dec 2008
      • 1967
      Thanks Bro, any suggestions on the fix? thanks
      • CapLeaker
        Leaking Member
        • 8327
        Nice vid. Your Mr.Buzzer is a interference suppression film capacitor 450nf, 275V. I'd check that first with a capacitance meter. It should read 450nF. With an Ohm meter it should be 1Meg and charging up a cap. You can find these caps on other power supply boards from other LCD monitors and TV's. Swap it, check your display again for noise in the signal.
        • ivtec
          • Dec 2008
          • 1967
          Thanks CapLeaker; why when i press on the top edge of the panel it goes away every time? see pic with attachment that i posted a couple threads above.
            • 12276
            • U.S.
            could try putting something there where you put the pressure, for better contact, then reassemble, seems like loose contact in that section.
            • ivtec
              • Dec 2008
              • 1967
              Hi guys: check this out my permanent fix for the bonding issue if that's the case! check pic attach.
              • DqMagetz
                Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                by DqMagetz
                Good day!
                I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                Here are the voltage readings:
                • Input – 19V (stable)
                • +LCDVDD – 3.3V briefly, then drops to 0V
                • EDP_HPD – 3.3V briefly, then drops to 0V
                • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                • EC BKOFF# – 1.8V briefly, then drops to 0V
                • PANEL_OD_EN – 0.3V
                Is it possible that the EC chip is corrupted or damag...
                07-12-2025, 09:37 PM
              • turmix
                AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                by turmix
                Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                During another reassembly, I made a mistake, and...
                01-29-2024, 03:48 AM
              • wizard13
                Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                by wizard13
                I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                I have checked the forum and the available documentation but could not find a solution specific to my issue.
                • Brand & Model: Dynabook Satellite Pro C50D-B-100
                • Part Number (P/N): PYU13E-00C00PFR
                • Serial Number (S/N): 22028896H
                • System Configuration (SC): A1PYU13E1127
                • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                • Power Input: DC 19V –
                02-28-2025, 02:43 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • cloudy
                HELP - Contrast/brightness issue with subtitles on screen
                by cloudy
                Hi everybody
                Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
                Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
                Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
                It occours both on ubuntu and windows...
                01-01-2023, 05:12 PM
