LG Flatron W1934S problem with backlight
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    I have problem with this monitor - when I turn monitor on, it works only few minutes (approximately 5-30 min) and then backlight turn off, LED lights green, picture stay on. I measured all electrolytic capacitors on power board and all are ok, but I only replace small 47uF capacitors with a little increased ESR.
    5V to logic board is ok, to inverter go 13.9V, on logic board are of course good voltages - 1.8 and 3.3V. I think the some ccfl tube is defective or only some wire had bad contact, but why it runs few minutes? Previously when I had problem with tubes it stays on only 1-2 seconds.. I add some photos when I arrive home. Could you advise me? Thanks for answer!
    Denis.
  • selldoor
    Slow Learner
    • 7870
    Re: LG Flatron W1934S problem with backlight
    If it all works except the back lights it could be heat related.
    Bad solder joint or faulty wiring to back lightwe will know better when we have good clear pictures- please post using manage attachments, not offsite.
    Test the voltage at blon pin when the lamps are on then when off.
    • DeniS182
      • Jun 2014
      • 328
      • Slovakia
      bl-on - 3.3V all the time when monitor is on.
      Now I test it with unscrewed pcbs, without ground connected to case and it works approximately 1 hour. I test it for longer time tomorrow.
      • selldoor
        Slow Learner
        • 7870
        I think the first thing to try would be to resolder all the connectors on both inverter transformers- better to remove the old solder and apply fresh. Do the same for the blue ceramic caps at the ends of the transformers.
        Have a close look with a magnifier at Pin8 on T501 looks cracked all round in the picture.
        • DeniS182
          • Jun 2014
          • 328
          • Slovakia
          I resolder it but it's not the problem. Today monitor runs 5 hours without turning off backlight. But when I screwed pcbs to case problem come back.
          • selldoor
            Slow Learner
            • 7870
            OK couple of things to try:
            1 Slacken off the screws - may be stressing the board in one direction.
            and see if it makes a difference.
            2. While it is on gently warm the boards with a hairdrier to see if it goes off quicker. If it does then try again from cold but heating smaller areas to locate the problem area.
            Also re solder the Blue high voltage caps and the lamp connectors - sorry should have tagged that on to the transformers.
            • DeniS182
              • Jun 2014
              • 328
              • Slovakia
              I tried all what you write me, but not change. It works fine all the time, but only when GND is not connected to case..
              • selldoor
                Slow Learner
                • 7870
                OK - Not a clue
                Is it the same if you only attach one board to the frame?
                If you set it up outside the frame and connect a ground point to the frame with a wire does it go off? ( trying to establish if it is the grounding that makes it go off or something else.
                Try it mounted on spacers/washers in case the board is bowed and touching the frame
                when hot.
                • DeniS182
                  • Jun 2014
                  • 328
                  • Slovakia
                  I tried all and I not resolve this problem. I test it with universal inverter from ebay and it works fine, but after few minutes monitor turns off and only blue led blinking. I mean it's overheating problem. Now, when I have universal inverter out from the case on air it works fine. Can you help me with this? Thanks.
                  • Chungalin
                    • Jul 2014
                    • 422
                    • Spain
                    I had a monitor failing the same way (backlight turned off after an hour or more) and it was a CCFL problem (upper ones). I recommend you to connect two external CCFL instead of upper lamps and try again. Anyway, replacing the lamps will be a time consuming operarion that requires a lot of skill and patience. And, unless they’re the exact replacement, you’ll need to replace all 4 lamps due to color differences.
                    • softman
                      • Feb 2017
                      • portugal
                      I am replacing the CCFL to led, i bought a kit that needs a conection between 15-30V were is recomended to do that conection? Have anyone tried this kits?
                      Realy sorry for my bad english.
                      Thanks.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        To convert CCFL to LED you need to identify as follows:
                        1. Power Supply for LED Driver. If the CCFL Inverter was working with 13Vdc then you need a DC-DC Step-up Module Bd. to bring the supply voltage up to power the LED Driver. OR if the CCFL Inverter was working with 24Vdc then you can use this supply voltage up to power the LED Driver.
                        2. BL-ON, EN or SW signal would be near the CCFL Inverter supply signal wires.
                        3. PWM, P-Dim, Adj Control signal would be near the CCFL Inverter supply signal wires.
                        4. GND-Chassis ground would be near the CCFL Inverter supply signal wires.
                        You would have to remove the CCFL and its supports and any other circuit Bd. in the Panel. The only thing you would re-use would be the white Reflector sheet that you would have to cut some holes to properly fit the LED lens through and re-use the Polariser and Prism sheets in the same order you removed them.
                        • Dobrowol
                          Asus GA402RK keyboard and kb backlight problem
                          by Dobrowol
                          Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                          04-28-2025, 04:30 PM
                        • fanaticgames
                          Samsung UE32D4010 Backlight problem, led ok
                          by fanaticgames
                          hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                          02-22-2023, 09:46 AM
                        • Honziq
                          Backlight problem - Asus M3200WU, board Gapal LA-L291p
                          by Honziq
                          I have this All-in-one PC, after SSD change there is no picture. I was found out it is a backlight problem, but LEDs are OK. There is 4 led strings each working on 42,4V, but from board is comming only 5V.
                          I was repaired many backlights before but this design i will not understand.
                          For me it looks like it is waiting for some signal from screen to start up the backlight or something like this. Nothing seems to be damaged or shorted here.
                          Can someone explain me please what to do, what to check?
                          Thanks....
                          11-20-2024, 01:24 PM
                        • grbo92
                          Backlight problem Acer LA-031P
                          by grbo92
                          i have one acer Nitro 5 without backlight on my desk.
                          Mainboard model: LA-L031P GH53Z REV 1B
                          Attached schematics and boardview are REV 1A, slightly different as REV 1B.
                          11411_LA-L031P-Acer_Nitro_5_AN515-45_AN517-41-GH53Z_Rev_ (1).zip
                          Repair history: customer cleaned dust and changed thermal paste, shortly after that there was no light
                          Notebook boots without problem and shows only image without backlight, HDMI output working. Optical inspection done, no burned or broken components. Tested also with a new display module....
                          09-09-2024, 03:49 AM
                        • triplefour
                          by triplefour
                          09-13-2023, 10:43 PM
