Planar PLL2410W LED monitor has weird screen issue
  • ManiN
    • Sep 2014
    • 5
    So I got this newer monitor from work since they were throwing it out. I was hoping the caps would be the issue, but no. It seems more of a bad connection of sorts? It seems heat is a factor because when it's been off for a while, it will turn on fine for a few minutes, then the lower 2/3 of the screen go to lines, and shortly after the top 1/3 does the same. After power cycling, it will happen much faster. This happens on different PCs, so I don't think that's the issue. I used the DVI port to connect it. Jiggling the cords didn't affect it.
    I can't send it back since I'm not the original owner. The CO. doesn't care to waste time on it since they're only $125 or so new.
    I made a video of the issue. Has anyone experienced this failure?
    http://youtu.be/1Yz2wfOd-6o
  • ManiN
    • Sep 2014
    • 5
    Re: Planar PLL2410W LED monitor has weird screen issue
    Hmmm I'm guessing this isn't common with the lack of replies. I'm thinking it's on the processing side, so I guess I'll take a look there and hope for some cold soldering or the like.
      That is the bad panel symptom. Is the T-CON board integrated with the panel?
      • ManiN
        • Sep 2014
        • 5
        There are 3 boards. One appears to be the main power supply. A smaller one that I would guess is the driver for the LED strips. Then the 3rd that has the connections to DVI, RGB, and ribbons to the LED panel and buttons. I would guess this last one is the same as the T-con board? The only board that is on the panel itself is the one that seems to simply divide all the connections along the edge of the panel.
        • turmix
          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
          by turmix
          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
          During another reassembly, I made a mistake, and...
          01-29-2024, 03:48 AM
        • wizard13
          Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
          by wizard13
          I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
          I have checked the forum and the available documentation but could not find a solution specific to my issue.
          • Brand & Model: Dynabook Satellite Pro C50D-B-100
          • Part Number (P/N): PYU13E-00C00PFR
          • Serial Number (S/N): 22028896H
          • System Configuration (SC): A1PYU13E1127
          • Motherboard Model: IP3_ACN16_MB_V21_20211222A
          • Power Input: DC 19V –
          02-28-2025, 02:43 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • cloudy
          HELP - Contrast/brightness issue with subtitles on screen
          by cloudy
          Hi everybody
          Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
          Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
          Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
          It occours both on ubuntu and windows...
          01-01-2023, 05:12 PM
        • 3D Modelka
          AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
          by 3D Modelka
          Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
          02-09-2024, 02:42 AM
