Philips 190S8 firmware
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    does anybody have firmware for this monitor. I nedd to program a new chip and I can't find it anywhere.
    thanks in advance.
  • kasfamily
    • Aug 2014
    • 765
    • Russia
    Re: Philips 190S8 firmware
    24c16
    • rippergr
      • May 2014
      • 345
      • Ελλάδα
      Thanks a lot.
      I will try it.
      • rippergr
        • May 2014
        • 345
        • Ελλάδα
        It works fine. Thanks.
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
        • gurj1979
          Ubiquiti firmware help. US-8-150W POE
          by gurj1979
          Hi guys.
          I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
          Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
          So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
          Got New chip and writes good.
          THE PROBLEM...
          It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
          Does anyone have a Good Firmware I can have?...
          07-22-2024, 05:13 PM
        • wattage
          AOC AG493UCX 49-inch monitor - Firmware request
          by wattage
          Hello Badcaps Community,
          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
          07-13-2025, 04:41 PM
        • george_gpu
          philips 24PFT5505_05/5500-series-fhd-led-tv firmware
          by george_gpu
          hi
          i need the latest firmware
          tv shows horizontal lines without drop it or shock it
          i have make a restore factory settings
          06-23-2023, 01:39 PM
        • sikocan
          NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
          by sikocan
          I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
          However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
          01-11-2024, 01:47 AM
