LG Flatron L1550S PSU - Samxon GF failure
  • Krankshaft
    replied
    Re: LG Flatron L1550S PSU - Samxon GF failure
    If your supply runs hot (and most all passively cooled inverter boards do) you will be back .
    I first ran into these caps in 07 on a customers Gateway LCD (Benq designed the inverter/power supply) all bulged replaced them with Nippon Chemicons and returned it to a happy customer.
    Samxon GFs are ticking time bombs similar to Nichicons screwup with their caps from 01 to 04. Both good brands that just made a mistake.
  • weirdlookinguy
    replied
    I think my flatron (19 wide, last year's model) has GF's too.
    Will let you guys know if it dies.
    Cheers.
  • Big Pope
    replied
    Actually, no need surprise for this matter. This is not the first time i saw Samxon GF 470uF 16V/25V failure on some hot hardwares, like LCD monitors. GF series is the old series(the first type) of low ESR caps and need more improves. See the Samxon Series Charts here -> http://www.samxon.com/SeriesChart.php
    By this reason, i always have some vigilance for GF series and sell GF series very carefully. I never get any stock of GF series, except 330uF 35V D10mm, which i got the stock on end of last year, because i want to test it on some Gigabyte motherbaords.
    I have installed much of Samxon GF 330uF 35V on some Gigabyte old motherbaords from DEC 2006 till to now. There is no any failure.
    Here is my caps database, http://www.capsmod.net/caps
    Anybody knows i keep stock for Samxon GF 330uF 35V D10x16mm only, no others GF series.
  • japlytic
    started a topic LG Flatron L1550S PSU - Samxon GF failure
    A friend at a local newsagent sent me an LG Flatron L1550S LCD monitor to fix and upon opening it, there was a bulged Samxon GF series capacitor before the output inductor on the +12V rail.
    Originally, there were 470uF 25V units before and after the first inductor on the +5V and +12V rails; however, I recommend using 1000uF 16V (before and after the +12V inductor) and 2200uF 10V (before and after the +5V inductor).
    Also, there was a 470uF 10V capacitor after the second +5V inductor and a 220uF 25V capacitor on the +12V rail, near the CCFL inverter.
    Finally, am I losing faith in Samxon low-ESR capacitors? (I think the values originally in the unit were a bit underrated)
  • Bartoloni
    Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
    by Bartoloni
    Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
    everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
    there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
    replaced the capacitor (330) and the inductor (R15) without any change
    any idea? very thank you!
    input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
    12-09-2024, 12:42 PM
  • badcap111
    How to read inductor specs?
    by badcap111
    I have a broken samsung galaxy s10 with missing inductor. I want to replace the missing inductor and I have found some vendors. But I don't understand how to read the specifications of the inductor. The specs are:
    INDUCTOR-SMD;470NH,20%,2520,T0.8,0.029OH
    I understand that the inductor is 470 nH with 20% margin, and the size is 2520 or 1008 (imperial measure), but what do T0.8,0.0290OH mean? I can't find any explanation on the web.
    09-12-2023, 01:25 PM
  • silver60618
    Blown Inductor on WD My Passport
    by silver60618
    Hi Guys, my WD My Passport drive powers on, then powers off. Ive taken out the motherboard and identified a blown Inductor. Im trying to recover my data only
    Reading between leads show nothing. If I removed this Inductor, what would be a suitable replacement? am I correct that its a ferrite Inductor is to just filter noise?
    Ive seen people just bridge them, any harm in replacing it with a differnt value Inductor?
    Lastly am I correct in thinking there is no polarity on the smd component?
    Thanks!...
    04-05-2024, 09:54 AM
    Corsair CX750M [Model 75-002019] - burned output toroid inductor
    by momaka
    Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
    So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
    09-19-2021, 08:44 PM
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    The TV does not turn on, the standby indicator is on. All voltages are present.
    Emms is dead. Not readable, not detected.
    Replaced emmc.
    But with another dump there is no launch
    Terminal log
    UART
    AC_ON
    RPMB key is not yet programmed
    HASH1_VERSION=0x00000000 64bit
    E-B
    FDE enabled
    layout pattern onebin by SAR7,0...
    06-01-2025, 02:11 AM
