Mag LT776s noise from speakers when off
  • oktools
    • Jul 2014
    I have a strange issue with my monitor. The speakers emit a very high pitch whine/squeal when the monitor is off. This happens when everything is connected, or when everything is disconnected(other than power input).
    This monitor is over ten years old and has just started to do this. I opened it up thinking it may be the inverter board and disconnected the board and the noise was still there.
    This model uses an external power brick as a power supply, so I then thought maybe it was going bad and allowing current through. I purchased a new power supply and plugged it in and the noise was still there.
    I plan on replacing some capacitors on the logic board. Does this seem like a valid route to go, or would it be very unlikely that this is caused by a bad capacitors on the board? Su'scon S5 series Caps(I do not know if these are low esr or not).
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Mag LT776s noise from speakers when off
    If you are saying the sound is only there when only the board with the speaker socket on is connected to the power supply then you really only need to look at that board.
    After the noise is sorted you may want to replace all the caps to prolong its life.
    BUT may not be worth it as the bulbs may be on their way out.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
      by momaka
      03-15-2023, 10:17 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • penangit
      Hp v193 monitor power supply board
      by penangit
      Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
      I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
      I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
      Steps taken so far:
      Checked all...
      02-21-2023, 04:00 AM
