Samsung SyncMaster 943BM - backlight only for half a second
  • Behemot
    • 4845
    • CZ
    Got this one with no 2 seconds to black but half a second to black. What I did so far:
    - checked all caps
    - checked inverter transformer
    - checked inverter trasistor STU309DH
    - checked fuse, output ceramic caps in the inverter
    - checked votlages under operation, everything seems fine incl. BL_EN
    - resoldered bunch of badly looking joints
    - tried different CCFL tubes
    The STU309DH has 7 V for a fraction of second on the drain than it slowly decreases to 0 V and again pulses to 7 V and goes down.
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung SyncMaster 943BM - backlight only for half a second
    Source connected?
    Dark mage on screen visible with flashlight?
    Power led change colour?... goes off.... stays on?
    • Behemot
      • 4845
      • CZ
      LED stays on, can see image with light so problem is clearly in the inverter. Time for pics I guess? Oh BTW, inverter controller is OZ9939GN.
      • selldoor
        Slow Learner
        • 7870
        BLON stays constant when lamps go off?
        • Behemot
          • 4845
          • CZ
          Yes it is 2,9 V the whole time.
          • selldoor
            Slow Learner
            • 7870
            I guess it is picture time.
            Have you tested the blue high voltage caps for leakage/shorts examined for cracks etc.
            • Behemot
              • 4845
              • CZ
              All of them measured +- 80 pF.
              • selldoor
                Slow Learner
                • 7870
                Sorry - missed it.
                • addytzu123
                  • Mar 2013
                  • 54
                  • ROMANIA
                  Just a thought - have you tried bypassing the protection circuit from pin 3?
                  In a transistor circuit protected by a fuse, the transistor will always blow to protect the fuse.
                  • Behemot
                    • 4845
                    • CZ
                    I could I guess…that is some ordinary resistor, could be 0,5 W or 0,25 W? And what than, look for a smoke?
                    • addytzu123
                      • Mar 2013
                      • 54
                      • ROMANIA
                      Well, it is 0,25W regular, and should enable the inverter to work with a "tired lamp"
                      • ek2oo2
                        • Oct 2013
                        • 24
                        • Philippines
                        Is that safe? What if there's a shorted component in the inverter circuit?
                        • Behemot
                          • 4845
                          • CZ
                          As I said, you have to look for smoke than
                          • addytzu123
                            • Mar 2013
                            • 54
                            • ROMANIA
                            If you have had a shorted component, the fuse should have blown by now.
                            This trick can be used if you determined that the inverter is ok, and positively identify one CCFL with problem, and you leave it disconnected.
                            If you are willing to compromise, than you can consider this a temporary fix (dimmed brightness) i suppose.
                            • Behemot
                              • 4845
                              • CZ
                              I have not identified bad tubes. I have tried different tubes (still in display BTW ) and it does exactly the same. Don't think two completely different panels will both have bad tubes…
                              • selldoor
                                Slow Learner
                                • 7870
                                I thought it was a fix mainly for a flickering bulb for example a bulb on its way out, although I did get someone to try it recently on a half second to black , but it didnt work.
                                What is does is it it doesnt operate on the signal that says the bulbs have not lit within a certain time giving a half dud or dim bulb chance to light as it extends the time to infinity. I think it is ok for a short test with a removable bridge or on a machine that is otherwise scrap as I dont know what effect a half working bulb will have on the inverter transformer. Probably kill it.
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  Pictures? - Tried jumpstarting power board with a resistor or 3v battery
                                  to see if the lights come on without the main board
                                  • addytzu123
                                    • Mar 2013
                                    • 54
                                    • ROMANIA
                                    And beside pictures, can you post the voltages on pins 2, 5, 6 and 10 (respective to GND) of the OZ9939 to see what protection kicks in ?
                                    • Behemot
                                      • 4845
                                      • CZ
                                      5,13 v, 0,23 v, 0 v, 2,89 v
                                        • 31259
                                        is IC101 supposed to be blown apart?
                                        rule :1 - visual inspection!
                                          09-07-2024, 05:50 AM
                                        • soopacrucial
                                          by soopacrucial
                                          Hi folks,
                                          10-29-2024, 02:40 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
