Samsung SyncMaster 943BM - backlight only for half a second
  • Behemot
    • 4845
    • CZ
    #41
    Re: Samsung SyncMaster 943BM - backlight only for half a second
    It occurs to me the display is very similar to a 932B I've been repairing few months ago, it uses the TM-0917 transformer. Looky
    Main differece is the SMD button board is connected to connector on signal board, not on the power board but the primary/secondary is basicaly same and the inverter looks almost the same.
    • lexwalker
      • Feb 2011
      • 307
      • Malaysia
      #42
      Did you check the resistance on secondary side of that transformer? Quite often a bad transformer can cause immediate lamp inverter shutdown...
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        #43
        what is that washer on there?
        Follow the white rabbit.
        • Behemot
          • 4845
          • CZ
          #44
          Cooling? There should be a strip of metal soldered in from the factory, they did not do it and you can see how darkened it is…so I've added it
          lexwalker: what do you mean?
            09-07-2024, 05:50 AM
          • soopacrucial
            Samsung Syncmaster 740BF repair
            by soopacrucial
            Hi folks,
            I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
            Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
            10-29-2024, 02:40 PM
            09-06-2024, 11:40 PM
            09-06-2024, 08:40 PM
