Acer X203H monitor, trying to ID power board part.
  • badcap400
    • Sep 2015
    • 13
    • usa
    So I was given a dead Acer X203H and I opened it up to look at the problem(s). Aside from needing to replace several dead capacitors, there is also a burned out "transformer" or voltage regulator(?) on the board. It is
    labeled FT0317 LCTC14A and is soldered on with 4 leads. I've googled the label id but can't come up with anything. Anyone have any ideas?
  • lotas
    • Jan 2016
    • 4759
    • Russia
    This is a noise suppression choke...
    • badcap400
      • Sep 2015
      • 13
      • usa
      That's great! Thank you. Is there a key to the label printed on there so I can id the right replacement choke for that or am I screwed and have to find a proper diagram with specs?
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Destroyer-Br
        [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
        by Destroyer-Br
        I'm working on an Acer Nitro 5 unit with the following specs:
        • Motherboard: LA-J871P Rev: 1B
        • Model: Acer AN515-55-59MT
        • S/N: NHQ7JAL00403906A973400
        • SNID: 03902728734
        Initial Issue
        The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
        After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
        04-17-2025, 08:18 PM
        by momaka
        03-15-2023, 10:17 PM
      • VitalComputing
        Help identifying component on main board of Acer KG281K monitor
        by VitalComputing
        Hi All
        This component is from the main board of an Acer monitor. I've been fighting this monitor all day and I refuse to let it beat me! Can anybody identify what this component might be?
        I have 20V on the input side of the component and nothing on the capacitors on the other side of it. Does it look damaged or does this component have two markings???
        thanks...
        02-12-2023, 02:41 PM
      • Roman555
        [Offer] Acer IPIMB-AR (w/o on-board gfx) of Acer Predator G5920 fullflash BIOS
        by Roman555
        I'd like to offer an Acer IPIMB-AR Rev: 1.02A fullflash BIOS (cleaned ME region). The model is for Acer Predator G5920.
        It is a model that is based on Intel Z77 PCH and doesn't have on-board graphics and video connectors.
        I suppose it doesn't have any restriction about discrete graphics cards (I mean they don't have to be in a whitelist).
        Please don't mistake this mainboard with a similar model with on-board graphics and based on Intel B75 PCH.
        Jumper FLASH_OVERRIDE
        default position: 1-2 - BIOS area protected
        position 2-3 allows to dump BIOS or write
        06-26-2025, 05:15 AM
