Help identifying component on main board of Acer KG281K monitor
  • VitalComputing
    • Dec 2021
    • 29
    • Ireland
    Re: Help identifying component on main board of Acer KG281K monitor
    Originally posted by R_J
    I suspect the microprocessor is not outputing the control signal, this may be due to a corrupt eeprom.
    Originally posted by lotas
    If there were short-circuited components at the HDMI input, then most likely the discharge slipped through this input and killed the processor.
    Yeah guys, I'd say it's one or the other. I tried freezing but no go. I've put it back together and I'll keep it in stores. Hopefully the guy I bought it from knocks his second KG281K one off the table some time soon!
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
      by JDC
      ONN 100012588
      Issue: No Power, Then Rebooting After Main Board Change
      Short answer: replace main board and power board
      Technical answer: replace main board and Q306 & Q307 on power board.
      Long answer:
      TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
