I have a dell 1800PF LCD that startsup with a normal picture then flashes black for a second. Then the video comes back sometimes in a different resolution. Then it will go black again and moments later return to another resolution.
It does this without regard to what computer it is connected to. After about 15 minutes it finally stops this flashing on and off and stabilizes on a resolution. Then it is just fine. It is almost like it is trying to detect the proper resolution. Or it may just be unable to keep the picture steady until some component comes up to temp or up to frequency.
I have looked at the caps and none seem vented, or buldging. Many people have had a problem with this monitor flickering. This has normally been solved by replacing the four caps on the inverter. This inverter looks different from ones that I see on other sites for this LCD. Mine does not have the four caps that most of them I have.
Is this type of behavior due to a caps problem?
