dell m6700 no video
  • NicolaM
    • Jan 2022
    • Italia
    dell m6700 no video
    hi,
    I have a dell m6700 that does not show video, the display turns on the backlight for about 3 seconds and then turns off, I also tried to connect an external HDMI and VGA monitor but the monitor doesn't even turn on
    I have already tried flashing both bios roms, I removed the discrete nvidia GPU, I changed the ram, I changed the wiring of the LCD panel but nothing seems to change.
    The logic board detects the absence of CPU and RAM, and GPU if I remove them.
    the leds do not indicate any anomaly, the only one that lights up is the caps lock one,iif you press the key on the keyboard it turns off but on the next start it stays on.
    if i holding down D generates the colors on the screen correctly, in diagnostics (holding down FN at start up) it does not show anything on the display, it makes 3 beeps instead, then 2 beeps and 1 beep.
    I have no idea what it could be, I only note that the CPU (which I have already changed) heats up a lot
  • andrhouseolly
    Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
    by andrhouseolly
    Hi.
    I kindly ask you to help me solve the problem.
    Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
    The board turns on, there is no image.
    Read more. When the power supply is connected, the front panel indicators light up briefly.
    When you press the power button, the button indicator lights up. The board works
    there is no image, there is no matrix initialization, there is no image on HDMI.
    When turned on, the fans do not spin, but when they warm up they start spinning.
    When you turn off the button, the fans spin up to full speed for a short...
    05-11-2024, 03:14 PM
  • PacoGT
    Gpu DELL OEM RTX3080 No video
    by PacoGT
    Hello friends, I have a question. They brought me this video card, a DELL RTX 3080. They told me that it fell and the impact no longer produced video.
    When trying it, it's as if it wanted to give video but in the end nothing, I already checked voltages etc. everything is as it should, but without video
    I suppose it could be a bios problem but since sometimes they don't tell you everything, I've searched for the bios everywhere but without success
    I can't find a backup or something to try to reprogram bios and see if it's the fault, could you help me maybe someone has one that...
    02-18-2025, 01:08 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • retrorepair2
    Dell E5470 LA-C631p - Short removed now turns on but no post/display
    by retrorepair2
    Got a really frustrating issue here, got a Dell laptop as above which initially had a short on the +POWER_SRC rail, discovered a short cap in a bank of 3 near PU801. Removed and verified the short was gone, it was and the laptop powered on, tried to load windows but just kept rebooting. Sometimes didn't post. Battery was charging.
    Stripped it back down and replaced the cap (assumed looking at the LA-632p schematic it's a 10U cap, no boardview so who really knows). Now the board doesn't charge the battery and while it powers on with a brief spin of the fans, there's no display on the...
    09-25-2025, 07:12 AM
  • manol278
    Dell laptop E6440 val91 la-9934p turns off
    by manol278
    Hi. I have problem with dell laptop E6440 val91 la-9934p rev.1.
    I turn on the laptop and it turns off instantly. After 5-6 attempts it turns on normally. I saw that it was burnt PU800, CD3301B Power Controller Chip.
    If you see in the photo someone tried to do bypass and remove PR831, PR832, PC820, PR838.
    I will replace CD3301B. I have the schematic but i dont know what are the characteristics of other componets to replace...
    [Mod. Edit]
    Schematic -> https://www.badcaps.net/forum/troubl...cs-theory/trou...
    01-26-2024, 11:50 AM
