Samsung S24C230BL DVI problem
  • angel-boy
    • 550
    • Romania
    Re: Samsung S24C230BL DVI problem
    The problem is the samsung magic color chip , you have to change that.
    • tibimakai
      • Jan 2012
      • 3680
      Constanta, ex Clujean aici.
      • tibimakai
        • Jan 2012
        • 3680
        That would be the main IC? That IC, from where could I purchase it, it's for sale?
        • angel-boy
          • 550
          • Romania
          Sa traiesti tibi ma bucur ca esti roman si ne putem ajuta. am mai avut monitoare samsung generatie mai noua , este chip defect magic color.
          mai simplu e sa scriu romaneste )
          • tibimakai
            • Jan 2012
            • 3680
            Poate e mai bine, sa scriem in engleza, ca si alti sa inteleaga.
            This chip is available and by replacing it, it will just work? No need for flashing or anything like that?
            • angel-boy
              • 550
              • Romania
              #26
              ( e mai greu la mine cu engleza, sper sa ne ajutam pe viitor )
              yes, only change the chip , this problem is on multiple monitors, S23A350H is one of them.
              Appears vga , hdmi , no signal , when plug in , monitor off , if remove cable, appears vga or hdmi no signal. i try another memory file ,no result.
              I hope I could help you !!!
              • tibimakai
                • Jan 2012
                • 3680
                With the A series, you can do a firmware update, through the VGA cable, but for this monitor, there is no available firmware.
                • angel-boy
                  • 550
                  • Romania
                  #28
                  I try , not working, no update need. did not solve my problem.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    With the A series, the monitor is working, just won't detect the input signal. If there is another issue, than most likely, a firmware update won't fix it.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Found the IC and ordered it from China, of course.
                      I will let everybody know of the outcome.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        The outcome is not good, I messed up the traces, when I have tried removing the IC. I had to heat it way to much, to be able to remove it.
                        I had to scrap that board and I have put the monitor away for a while.
                        Not to long ago, I have found a controller board kit on aliexpress, that connected to the Samsung LCD it will make it work.
                        This is a diy job, because the board(s) won't fit in the metal cage. There are (more)buttons then the original Samsung one.
                        http://www.aliexpress.com/item/HDMI-...366904776.html
                        There is another kit, that has even more features, but I just need it as a monitor.
                        I have plugged everything in and it's working great. It needs a 12V power supply, though. The original Samsung won't work. I don't know, how many amps it needs yet.
                        Most likely, I will use stand-offs and install the main board against the back cover. The inverter, I will just tape it to the LCD and the button board, I still have to figure out how to mount it.
                        • CptChronic
                          Samsung LU32J590UQUXEN Monitor display problem
                          by CptChronic
                          I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
                          Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
                          But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
                          04-24-2023, 04:33 PM
                          09-07-2024, 05:50 AM
                        • Mirenia
                          Samsung UEMU6199U - no Standby - bad Firmware?
                          by Mirenia
                          I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
                          Voltages on the power supply board is okay. Backlight test is also okay.
                          I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
                          So I think my TV has exactly this issue.
                          Can someone please fix the dump?
                          And how do you do that?
                          As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
                          05-12-2025, 06:13 AM
                        • soso technician
                          LG monitor ips226v-pnx firmware need
                          by soso technician
                          hi...lg monitor is dead...it seems to have corrupted firmware...because it is assembled in my country it may have different model name around globe...i will send pictures of mainboard,lables and dump firmware that i extracted from faulty board with name old.bin...if you have exact board (its common on diferent lg monitores) please share it...thank you.
                          ips226v
                          EAX63330406(0)
                          110527 D.ZH
                          it has 25X20BW eeprom...
                          03-21-2025, 06:01 AM
                          09-06-2024, 11:40 PM
