Aoc U2879VF
  • Viktor Árvai
    • May 2024
    • 32
    • hungary
    Aoc U2879VF
    Hi !
    i have an aoc u2879vf which died 3 days ago.
    I legt the pc it worked fine , came back to a mostly purple screen with flickerings all over, i unplugged the dp cable ,back in ,was the same .
    I unplugged the mains , plugged it in from that on no power .
    Dissasembled the display found no shorts whatso ever , the power on button works , tested it with a multimeter, and there are voltages present not all around the board but fairly everywhere.
    Since i did not found any info from this monitor on the internet i thought i give it a try here , if anyone has a tip or an ide please let me know , this monitor costs more then when i bought it 7 years ago ….
    thank you very much!
  • gamartinelli
    Asus VG248QE won't power on / purple light
    by gamartinelli
    I have an Asus VG248QE that all suddenly stopped working. Everything was fine, I had my PC connected to the HDMI port and never had any issues. Then I decided to plug a laptop in the DisplayPort (USB-C to DP cable). It worked fine for a few hours, I left, at some point the monitor went to sleep mode and when I came back and moved the mouse monitor didn't wake up. The power button lights up in blue when the signal is good and amber when in sleep mode / no signal turned purple (first time I saw that). Did some research but couldn't find a way to bring my monitor back to life....
    09-29-2022, 04:15 PM
    by momaka
    03-15-2023, 10:17 PM
  • wattage
    by wattage
    Hello Badcaps Community,
    07-13-2025, 04:41 PM
  • ant3202
    HP 27es - LED monitor - Monitor Flashing On - Off
    by ant3202
    Hi Everyone
    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
    https://www.badcaps.net/forum/troubl...lashing-on-off
    The monitor is HP 27es LED Monitor
    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
    The monitor will randomly blackout and display no signal and will recover again.
    Sometimes need to power and off again to restore the display but...
    03-20-2025, 07:30 PM
  • mobotest
    Acer S231HL LCD LED Monitor - No power then works after unplugged for a month
    by mobotest
    Monitor:
    Acer S231HL LCD LED
    Adapter:
    Delta Electronics ADP-40PH 19V 2.1 AC/DC
    Symptom:
    No monitor power LED light. Monitor did not turn on.
    Adapter measured 18.92V at adapter barrel connector.
    Then after a month of leaving monitor unplugged, monitor started working again yesterday.
    Adapter still measures 18.92V.
    Questions:
    1. Is 18.92V output within spec for a 19V adapter? or is it a sign of future failure?
    2. Does the described behavior indicate some component in the monitor that is faulty...
    01-16-2021, 03:54 AM
