Calculate resistor value for an inverter bypass of LG Flatron W1934s
    Hi , I have a LG W1934S monitor with a lamp that does not work , I want to use a resistor to bypass the system of investor protection.
    I have seen another post of a guy, I quote here what he said :
    Ohms law . At a rough guess at CCFL runs at 650 - 1000 Volts and draws 3.5 mA.
    E / I = R or 800/.004 = 200Kohms
    I E = P or X .004 X 800 = 3.2 watts
    So a 200K ohm 5 watt resistor connector hooked to an Appropriate Should do it . Probably be a good idea to to use a resistor rated for high voltage .
    No warranty at this price .
    Now , I've been thinking it Should be possible to do something similar except use two resistors ( 180K , 20K ) in series to form a voltage divider so Could you actually measure the output voltage without frying a DMM .
    PlainBill
    The details of my monitor panel are in this picture:
    I have doubts and do not know exactly what value should I choose to do the calculation
    Sorry for my english
    Greetings from Spain , thank you very much
    Re: Calculate resistor value for an inverter bypass of LG Flatron W1934s
    That spec sheet is for the T-CON electronic not for the lamp section.
      You're right, sorry. These are the correct data:
        So the typical power is 730V * .007A = 5.11W, so the equivalent resistance is about 104K Ohms and should be rated at 10W (twice as much for safe margin).
        But since the breakdown voltage that typical resistor can handle is about 500V, so you should use may be 4 or more resistors in series then you can smaller resistor Wattage to add them up to 10W, IE. four 27K Ohms 3W resistor (if the spec indicate the breakdown voltage of 500V) will give you 12W of power handling and 2KV breakdown (start up voltage can be as high as 1700V per spec).
          Hello again, I bought 4 resistors on ebay of 27kΩ, but with these other data
          Rated Power: 5 Watts.
          Max. Working Voltage: 700V.
          Dielectric Withstanding voltage: 1000V.
          I think in total would be 20W and 2.8KV.
          Is it right? Can I use them without problems?
          They look like these
          Thank you very much again and sorry for the inconvenience
            Those will be fine. Higher Wattage will have higher breakdown voltage.
