Calculate resistor value for an inverter bypass of LG Flatron W1934s
  • javalinex
    • Apr 2014
    • 5
    • Spain
    Hi , I have a LG W1934S monitor with a lamp that does not work , I want to use a resistor to bypass the system of investor protection.
    I have seen another post of a guy, I quote here what he said :
    Ohms law . At a rough guess at CCFL runs at 650 - 1000 Volts and draws 3.5 mA.
    E / I = R or 800/.004 = 200Kohms
    I E = P or X .004 X 800 = 3.2 watts
    So a 200K ohm 5 watt resistor connector hooked to an Appropriate Should do it . Probably be a good idea to to use a resistor rated for high voltage .
    No warranty at this price .
    Now , I've been thinking it Should be possible to do something similar except use two resistors ( 180K , 20K ) in series to form a voltage divider so Could you actually measure the output voltage without frying a DMM .
    PlainBill
    The details of my monitor panel are in this picture:
    I have doubts and do not know exactly what value should I choose to do the calculation
    Sorry for my english
    Greetings from Spain , thank you very much
    Re: Calculate resistor value for an inverter bypass of LG Flatron W1934s
    That spec sheet is for the T-CON electronic not for the lamp section.
    • javalinex
      • Apr 2014
      • 5
      • Spain
      You're right, sorry. These are the correct data:
        So the typical power is 730V * .007A = 5.11W, so the equivalent resistance is about 104K Ohms and should be rated at 10W (twice as much for safe margin).
        But since the breakdown voltage that typical resistor can handle is about 500V, so you should use may be 4 or more resistors in series then you can smaller resistor Wattage to add them up to 10W, IE. four 27K Ohms 3W resistor (if the spec indicate the breakdown voltage of 500V) will give you 12W of power handling and 2KV breakdown (start up voltage can be as high as 1700V per spec).
        • javalinex
          • Apr 2014
          • 5
          • Spain
          Hello again, I bought 4 resistors on ebay of 27kΞ©, but with these other data
          Rated Power: 5 Watts.
          Max. Working Voltage: 700V.
          Dielectric Withstanding voltage: 1000V.
          I think in total would be 20W and 2.8KV.
          Is it right? Can I use them without problems?
          They look like these
          Thank you very much again and sorry for the inconvenience
            Those will be fine. Higher Wattage will have higher breakdown voltage.
            • Spudgun
              Why doesn't current just bypass faulty capacitors.
              by Spudgun
              Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
              04-01-2025, 10:33 AM
            • Arshad alam4659
              a1466 smc bypass
              by Arshad alam4659
              what is smc bypass and how does it work and how to bypass it i want to know can anyone tell me about it
              11-09-2024, 08:22 AM
            • oxonater
              Apple MacBook Pro A2141 16" IC BYPASS
              by oxonater
              Hi everyone hope all are well
              I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
              I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
              The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
              I suppose it's worth noting googling the part package brings up various...
              10-23-2024, 11:21 PM
            • Yacine007
              Lenovo yoga c740-5IML MDM bypass
              by Yacine007
              hello everyone hope everything good,
              please can someone help me to bypass this laptop lenovo yoga c740-5iml, i canΒ΄t create local account i tried several commands CMD without succes.
              Model : 81TD
              SN : PF2AFN38
              MO : PF9XB0525250
              MTM : 81TD0067MH
              Factory ID : JVHFC1
              MFG : 25/05/20...
              03-21-2025, 08:53 AM
            • harounHD
              Macbook a1989 and a2338 icloud bypass
              by harounHD
              Is there a solution for Macbook a1989 and a2338 icloud bypass , i saw a video on youtube of someone using a bootable usb to unlock it
              02-01-2025, 03:23 AM
