Dell E2209Wf 2 seconds to black
  • happycamper4015
    • Apr 2014
    • 8
    Great forum...
    I opened up my Dell E2209Wf monitor and in the process of removing one of the CCFL connectors I pulled one of the wires out. Anyone have a source for these? I need the male end.
    I did get a broken screen from a local repair guy and have used that to test the CCFL's (it had one good one in it). I get the 2-3 seconds to black when replacing each of the 4 in the Dell monitor. There is a slight buzzing sound when the CCFL is on.
    Is the typical process just to replace the Caps and go from there? There seem to be only 5 of them to replace on this board.
  • Jerryv
    • Oct 2012
    • 22
    Re: Dell E2209Wf 2 seconds to black
    Why not take a lead from the broken screen and splice the wires? Use a couple of layers of shrink tube and you should be ok. Did the test lamp light up completely in each of the four sockets? If it did, then I would replace the caps and try it. If it didn't then I might suspect the transformer.
    Jerry
    • happycamper4015
      • Apr 2014
      • 8
      The spare lit up fine in all 4 slots. My back up plan was to use the spare connector but it doesn't have the little retaining clip and seems a bit loose in the socket. I'll replace the caps and see what happens.
      Thanks.
      • happycamper4015
        • Apr 2014
        • 8
        Update: I replaced the caps on the inverter board and nothing changed - still 2 seconds to black. I found an old monitor that had two back light connectors and hooked them up to two of the four on the broken monitor. The first two I tried did nothing (2 sec to blk). When I swapped them for the other two, the back light on the broken monitor and the test monitor both worked fine - no 2 seconds to black.
        I assume this implies that 2 of my 4 back lights are having trouble?
          • 31047
          no, it means they are all bad - but 2 are worse.
          i mean, they are all the same age!
          so you need new tubes, or an led kit.
          • HTR-Informatique
            by HTR-Informatique
            02-09-2025, 06:51 AM
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • jake-b
            dell e6540 boots to black screen (no dell logo)
            by jake-b
            good morning all,
            i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
            01-08-2024, 10:29 AM
          • Swedishpower
            Dell G3 15 3500 black screen
            by Swedishpower
            Hello
            I have search everywhere for a solution for my problem, but cant find it anywhere.
            When I was away to trow some garbage i always look in the electronic bin.
            and this time i find a laptop.
            Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
            the lamp for charmig is white.
            Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
            but no Dell logo.
            I tryed with a hdmi cable to another screen, still black.
            I started to search solution and tryed...
            07-06-2025, 06:18 AM
