Dell 3007wfp vertical green line
  • levesqu6
    • Mar 2014
    • 3
    I'm looking at a Dell 3007wfp that is exhibiting a green vertical line across the screen. The screen will sometimes flicker and the screen will occasionally flicker to dimmer colors. From what my research has shown it is likely something to do with the TCON or tab bonds. How likely do you guys think this is fixable?
    the panel is a LM300W01 and heres the datasheet
  • Rtech
    • Jul 2010
    • 1095
    Re: Dell 3007wfp vertical green line
    Probably the Screen panel that is faulty, replacement required I should imagine.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • cubytus
      Samsung UN50TU8000FXZC shows thin horizontal green line when warm
      by cubytus
      Hi to all,
      I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
      I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
      Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
      01-10-2024, 01:26 AM
    • hoot
      One vertical green line on my AQUOS LC-70LE740E TV
      by hoot
      on my AQUOS LC-70LE740E LCD TV there is a vertical green line on the screen. (pictures below)
      Does anyone know what the issue could be?
      Up close it looks something like this.
      Can this fault be serviced?
      What I want to do is the following:
      gently pressing on the ribbon connections along the top and bottom of the panel in the area of that line. Pushing a driver IC onto the flex cable it sits on to restore the lost connection. When the problematic area is found installing...
      11-21-2021, 07:48 AM
    • TrueSword88
      Kogan - KALED65XU9220STB - Blue Vertical Line
      by TrueSword88
      Hi all.
      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
      The line just happens to coincide with the end of COF and start of the next COF (attached).
      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
      Hoping to fix...
      05-05-2023, 04:28 PM
    • almarhum
      To fix laptop screen vertical line by working on its EDP cable
      by almarhum
      Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
      As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
      05-07-2024, 02:12 PM
