Sync Master 940n fuse
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hi, monitor did not light up backlight. I replace caps on it and i have 1-2 sec backlight and then secondary fuse blown. can you help me
    ...the quieter you become the more you are able to hear...
  • philliesfan30m
    • Aug 2013
    • 542
    Re: Sync Master 940n fuse
    that mosfet on the heatsink might be bad. get the number off the mosfet. you might have other problems as well.
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      it is MBFR20100CT i check it with diode test and OK
      • philliesfan30m
        • Aug 2013
        • 542
        test the mosfets on the other heatsink
        • selldoor
          Slow Learner
          • 7870
          Check you put the caps in the right way round?
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            other one is DMO565R it has a 6 leg. CAnnot find datasheet
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              caps is in the right way
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                is this readig ok on CCFL transformer i have shorted all primary
                • lexwalker
                  • Feb 2011
                  • 307
                  • Malaysia
                  Not that one (which sounds like FSDM0565RB switched mode PWM power I.C)...
                  Check the attached image. Remove the MOSFETs (as highlighted in yellow) and measure them off the board. These are surface mount MOSFETs. Also a reading of 1.3kOhm is little high for the transformer secondary windings (usually around 1.1kOhm or less). Possible bad transformer...
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4289
                    • Italy - Milan
                    very nice added graphics in your post #8 image.. which program do you use?
                    Also follow Budm posts, he links always a method to test for bad ccfl using unusable broken low-consumption cfl lamps.
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      @ Davi.p - program is 'Jing' and its a free screen capture tool, i use it all the time
                      You ment sticky thread?
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        that 2 MOSFETs is a 4502C how can i test them? In datasheet i can understand where is the D,G,S
                        • rtstorm
                          • Feb 2012
                          • 971
                          • Croatia
                          i check them, and i this i found a fail
                          one og them is shorten on pin2 and pin 7, other is 71kOHM and thay are the same markings (4502C AA6PN)
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4289
                            • Italy - Milan
                            ok let us to know if you fix it when you will change it.
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              ok, i will order it and feedback when arives
                              • lexwalker
                                • Feb 2011
                                • 307
                                • Malaysia
                                According to the service manual, supposed to be AM4512C but it seems the manufacturer were using AM4502C on your unit...
                                Yups, that would have possibly cause the fuse to blow. You may want to replace both of them (with new ones) just in case. As for the 2 seconds to black, check the secondaries of the second transformer and see if they are the same as the first transformer. As mentioned earlier, 1.3kOhm sounds a little high...
                                • rtstorm
                                  • Feb 2012
                                  • 971
                                  • Croatia
                                  i replace 2 MOSFET and monitor is now working, thank you all.
                                  • corrize
                                    A funny fuse story – Lumix LX100 II
                                    by corrize
                                    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                    10-19-2023, 09:58 AM
                                    Surface Mount Fuses Fundamentals Datasheet
                                    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                    10-07-2024, 06:07 AM
                                  • jesterace
                                    Samsung UE46ES8000 Blown fuse but no other signs of short
                                    by jesterace
                                    Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                    09-11-2024, 03:14 PM
                                  • jshhh
                                    Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                    by jshhh
                                    Hi guys,
                                    I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                    How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                    Anybody know how to remove this type of fuse?
                                    (The fuse is toward the bottom of the image labeled F2)...
                                    06-17-2025, 01:35 AM
                                  • Babbar
                                    by Babbar
                                    04-12-2024, 01:12 AM
