dell 2407wfp black out
  • scuby
    • Jan 2014
    • 33
    • netherlands
    Hello all
    My first thread!
    I have a dell 2407wfp. I have tested it on multiple computers with different graphics cards. It's definitely the monitor itself not the GPU or driver.
    I'm thinking it's a heat issue. I did modify the outer plastic cover a little to give it more ventilation to no avail.
    When 'cold' the monitor will run for about an hour depending on the ambient temperature (the warmer the shorter teh duration)
    Once it blacks out, no buttons respond, but all stays green not like sleep mode which is orange. Unplug power, plug back in and it starts up ALWAYS displaying the DELL startup logo and then will black out again quickly and increasingly quickly untill it just stays black, but always displaying the DELL logo. Here's a video.
    Where to start with the trusty multimeter? Any ideas?
    cheers,
    Video of monitor behaviour HERE
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: dell 2407wfp black out
    Id start with a trusty hairdrier - gently heat sections of the boards at a time until hopefully you narrow down the spot where heat causes it to shut down. If you are lucky it wont be the main processor.
    • HTR-Informatique
      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
      by HTR-Informatique
      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
      I also changed the screen because the PC fell and the screen was broken.
      I changed the battery with a new and original battery.
      I also had corrosion/oxidation on the...
      02-09-2025, 06:51 AM
    • Borse2008
      by Borse2008
      • There’s
      07-15-2025, 04:55 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • jake-b
      dell e6540 boots to black screen (no dell logo)
      by jake-b
      good morning all,
      i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
      01-08-2024, 10:29 AM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
