Dell P2416DB - no picture
This topic has been answered.
  • YellowJacket
    • Dec 2020
    • 105
    • Slovakia
    Hi friends,
    I am here for asking for a little help with this monitor. It reacts to pressing the power button, but the only thing I get is working back light, with no picture. I was measuring all power voltages, you can see them in attached picture. There is 3.3V on the SPI ROM chip, and I can see healthy-looking communication on it ( pin 1 is changing ) after powering on. I can see nice clock signal on both crystals. I am even able to measure some low voltage data signals on LDVDS cable. So I believe, my issue in on the panel itself. I proved it by measuring VGH1 signal on a test point and saw, that voltage was initially high enough ( 31.2V ), then it felt down almost to 0V ), VGL1, is all time zero volts, only low negative spike around -1.6V, but it should be around -7V if I am not mistaken.
    Now the question is - is it at least partially fixable, like in TV case, where you block some clock signals (SCK)? I have never done it in monitors, since I don't fix them often. There are too many flex cables going to the screen, and I have no idea, how to check faulty "part in the screen", which can I block ( if I ever can ). It is my monitor, so I don't mind, if it won't last too long, just want to save it.
    Thank you for any suggestion, and feel free, if you need some additional information/photo/measurement.
  • Answer selected by YellowJacket at 01-16-2024, 01:39 PM.
    lotas
    • Jan 2016
    • 4554
    • Russia
    Yes, you need to check which side the short is on (where the resistance is lower, the short is there), then remove the resistors on that side and check.
    • lotas
      • Jan 2016
      • 4554
      • Russia
      Yes, the problem is in the panel; already two such monitors with the M238DAN01 panel had low resistance at CK(1-8)B1 relative to ground.
      Take a photo of the strip (T-CON) on the left and right sides, I will show you where to check.
      • YellowJacket
        • Dec 2020
        • 105
        • Slovakia
        Thank you lotas (again).
        Left and right side atached. I believe, I should check around 0 ohm resistors, right? Resistance to ground is in Mohms on CKxxx though. But there is only 20 ohms on VSTB1 and VSTA1.
        • lotas
          • Jan 2016
          • 4554
          • Russia
          • YellowJacket
            • Dec 2020
            • 105
            • Slovakia
            Another solved case thanks to you, Lotas. It works now ( removed all resistors on right side, where was smaller resistance ).
            Big thanks to you!
            • lotas
              • Jan 2016
              • 4554
              • Russia
              Ok!
              • Darkic5
                • Dec 2021
                • 3
                • Netherlands
                Hi lotas and YellowJacket, my P2416DB monitor just died during use. The power led lights up, and when powering on it temporarily shows some vague vertical and horizontal lines, after which it turns to complete black.
                I checked the voltages YellowJacket described, and they are all identical to your measurements.
                After checking the resistors on the panel I find the following values:
                Left side: CK1B1 - CK6B1: 7,8M; CK7B1: 8 Ohm; CK8B1: 65 Ohm; VSTB1: 8M
                Right side: CK1A1 - CK6A1: 7.8M; CK7A1: 4.4 Ohm; CK8A1: 61 Ohm; VSTA1: 8M​
                This is my first time fixing a panel, so I don't know what to do now. Are the 4.4 and 8 Ohm values too low? Should I remove all low value resistors (on both sides), or just the 4.4 Ohm? After removing, should I power it on in this state? Any way to fix the short, or are these shorts in the panel itself?
                Please let me know if I should check anything additional. Hope I can save this screen to use it a little longer!
                • lotas
                  • Jan 2016
                  • 4554
                  • Russia
                  Remove resistors only from one side, where the resistance is lower. Yes, this short circuit occurs in the panel itself.
                  • Darkic5
                    • Dec 2021
                    • 3
                    • Netherlands
                    Thanks so much lotas! I removed both the 4.4 and 61 Ohm resistors on the right side, and now all resistors on the left show 4.7 to 4.8 MOhms. It works again now! Although, I have no clue how and why. Can you direct me to a source where this is explained perhaps?
                    • lotas
                      • Jan 2016
                      • 4554
                      • Russia
                      The panel is divided into left and right parts and these signals are duplicated for each half, you had a short circuit in the panel on one part and when power was applied T-con blocked the supply voltage to the panel, after removing the jumpers (resistors with zero resistance) the short circuit disappeared and the voltage recovered and began to work from one half.
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • reessi
                        Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                        by reessi
                        Hello:
                        I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                        I started on the ACER:
                        Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                        All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                        I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                        10-29-2024, 11:31 AM
                      • timeless
                        Dell U2518 no picture
                        by timeless
                        I've been troubleshooting a Dell U2518 that produces no picture yet the backlight is turned on, the PSU produces 19v, It is detected over HDM and its firmware could be upgraded over USB. So to me the controller board and PSU seems (somewhat) functional.
                        There is however a ticking noise from the T-Con board to the left side of the RT6811 chip when power on (not when off). Also the RT6811 chip gets quite hot (cannot be touched for long) otherwise there is no physical sign of damage and everything around the board is neatly covered with plastics and does not show any...
                        04-14-2024, 08:30 AM
                      • huzo
                        Dell 5590 no image on LCD,HDMI works ,the board works...
                        by huzo
                        The board is LA-F411P ,DELL 5590 ...
                        The screen polarises,no backlight,no image,only black screen,tried another screen,the same,so there is no backlight,but there should be an image when i shine a lamp behind the screen,but there is none...only dark screen...when screen is connected and i press F8 to turn the image over to the external monitor, the external monitor gets coloured bars ,but when i disconnect the cable from the EDP ,the HDMI picture is good...What could be the problem? I don't have another edp cable, but i measured it with meter and it comes out good...i am baffled......
                        02-16-2025, 03:08 PM
                      • Tr0ll
                        by Tr0ll
                        Original T-con:
                        First replacement T-con:
                        10-07-2023, 07:48 PM
