Vintage Philips 4BM2797 CRT BW monitor repair/tuneup
  • mitchw
    • 152
    • Slovenia
    I have a Philips 4BM2797 black and white VGA CRT monitor that is very dim. If I put the brightness at medium (indent at the pot), the text is barely visible in a moderately lit room.
    I looked around for a service manual, but was unable to find one. Also there are no G2/Focus adjustments on flyback...
    There is a row of adjustment trimmers, but they aren't marked..
    Anyone has any info about it?
  • mitchw
    • 152
    • Slovenia
    Anyways, I marked all the pots with sharpie and started turning them slightly. The one marked 3537 is clearly the G2 voltage control as I was able to crank it up so the retrace lines started to show up. This is the third one from the rear side...
    Now the image is much brighter, and still very sharp. So most likely the tube is in a pretty good condition still
    • keepread
      Dell monitor PSU vs Dell laptop PSU
      by keepread
      Hi there!
      Someone gave me their old monitor, it's Dell S2715ht.
      The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
      Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
      10-30-2025, 04:45 PM
    • logocar3
      Philips 288P6LJEB/27 monitor PSU outputting 8V instead of 12V
      by logocar3
      I am having problem with fixing Philips 288P6LJEB/27 monitor PSU, board number 715G6457-P01-000-0010.
      Data:
      - Schematic is attached to post
      - Photos can be found on flicker: https://www.flickr.com/photos/198547898@N03
      Problem:
      - PSU board have power outputs at 5.2V, 12V and 24V - board is correctly outputting only 5.2V (correct), and not 12V (without load only 8.16V) or 24V (without load 0V)
      State of PCB / monitor:
      - Bought defect monitor from a company auction
      - There were some attempts to fix...
      06-19-2023, 11:40 PM
    • Schwoin
      Philips 243v5lhsb00 Monitor Picture too bright
      by Schwoin
      Hey everyone,
      the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
      While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
      you can see them on the top half of the photo.
      At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
      03-21-2023, 12:40 PM
    • wattage
      by wattage
      Hello Badcaps Community,
      07-13-2025, 04:41 PM
    • ant3202
      HP 27es - LED monitor - Monitor Flashing On - Off
      by ant3202
      Hi Everyone
      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
      https://www.badcaps.net/forum/troubl...lashing-on-off
      The monitor is HP 27es LED Monitor
      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
      The monitor will randomly blackout and display no signal and will recover again.
      Sometimes need to power and off again to restore the display but...
      03-20-2025, 07:30 PM
