HP iQ790 touch screen conversion
  • spleenharvester
    • Mar 2010
    • 903
    Hey all.
    Basically I have an M190A1 touch panel from a defunct HP iQ790. A few years back I had a HP W1907v, and used the touch panel and its controller board to convert the W1907v into a touch screen.
    The panel has two cameras, one at the top left and one at the top right, each with their own lead running to the controller board via zif connector. If memory serves, each lead has about 7 connections running from it.
    All went well when I got it back together, was very pleased with the result. Until I found out the top inch or so of the touch screen doesn't respond to touch properly. The touch overlay is a Nextwindow 1950 panel.
    It acts as if one of the cameras stops working intermittently - the touch responds but rapidly jumps around from one side to the other, and even when it doesn't, it's very very shakey.
    So I pulled it apart again, and found one of the leads appears to be slightly damaged. One of the gold pins is missing its tip, but not all the way along, most of it is still there.
    I'm pretty sure it's still making contact, but I cannot think of any other explanation as to why this is happening. Has anyone had any experience with one of these touch panels? What would be the easiest way to repair the damage on this zif connection?
    I'll get some pictures up later, only pic I can find right now is this one, of the controller board: http://i.imgur.com/gr32ohul.jpg (One of the zif fasteners is missing I know, it was found and later reattached to the connector)
    Cheers!
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 903
    Re: HP iQ790 touch screen conversion
    Update, dug this thing out of the garage. I tried wiggling the cable out slowly on the other side and the same shaky thing happened at the bottom of the screen. So it does appear to be a problem with the cable.
    Pic of the offending connection: http://i.imgur.com/IWtf8w9.jpg
    I'm guessing I need to solder a jump lead from the cable side directly onto the pins of the connector? Is it safe to do this without damaging the zif cable? I'm going to need to be dead careful of that CCFL too.
    Gonna find a multimeter now and check the continuity between the two sides.
    It's a shame, because the rest of the screen works perfectly.
    [EDIT] Uh oh, multimeter test between pins on cable and pins on connector tests okay. Fault is somewhere further along cable then? It feels very weak...
    [EDIT2] The fault was one of the cameras. I lifted it up to look at it at the cable snapped off it was that weak. Looks like I'm SOL. :/
    • AJ847.63e
      HP Envy X360 13-bf0073TU (6X0Q8PA) Touch Screen Compatibility. Screen P/N N15665-001 - BOE NV133WUM-A65
      by AJ847.63e
      Hi All,
      We've got a HP Envy 12th gen that has been dropped and the LCD panel itself has cracked. The glass is fine just the panel itself is cracked. We ordered a replacement screen assembly using the part number off the HP part surfer website.
      Upon installation the touch screen now does not work either in UEFI or win 11. Device manager under the "intel Precise touch and Stylus) menu notes "This device cannot start (code 10) Status_Device_Power_Failure".
      I've tried all the usual troubleshooting steps like reinstalling the driver, uninstalling...
      04-04-2024, 05:29 PM
    • Yehuda170
      ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
      by Yehuda170
      original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
      replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
      now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
      with original broken screen i can see in device manager touch screen in human interfaces
      but with the new screen it's not showing in device manager
      is it lenovo blocking it? is it driver missing?
      I²C is a headache
      07-14-2023, 01:29 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • Gabriel Lucas
      microsoft surface pro 5 touch screen not working
      by Gabriel Lucas
      Hello everyone, I bought a Microsoft Surface Pro 5 and the touch doesn't work. According to what the previous owner said, the screen stopped working after an update. The screen has no physical damage, and the touch works for 1 second when it turns on and then stops working. I've tried updating the drivers, formatting, and returning to factory defaults, but nothing worked. Can you help me?
      02-18-2025, 09:24 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
